Maxigo 0.8.3b (update-25 May 2007)
Haha I meant it more like 'no idea why it's working this time, while it didn't previously'
I didn't change anything, so it was a bit of a surprise.
Another thing, would it perhaps be a nice idea to have presets?
I've written a preset manager for maxscript about a month ago, if you want, you can use it.
What do you mean by presets? Material presets or export dialog presets?
I've been thinking of doing a folder like Scripts\Maxigo\Presets. Whatever *.igm's are thre will be shown as a preset under importMat (or in some place else cause i'm planning to rewritre the material system a bit). Then we can include some default *.igm's with the package.
What exactly is this preset manager of yours? What it does?
I was thinking more of presets for the export settings.
The script I wrote basically offers a fast and easy way to save structure variables into a .ini file. For more info, check out this thread on CGTalk:
http://forums.cgsociety.org/showthread. ... 8&t=496482
Hey. I just started using the Indigo render. I opened up one of my old scenes for a test, but got a few errors. The scene is very big. 292k+ polys. I know. I really need to work on efficiency. Anyways, I followed your advice and used obj. I got an error saying something along the lines of no integer existing after some point. Anyways, I then tried the xml format. No errors, but it appears as if my model was disassembled and spread apart. Various components are separated from the main model. Any suggestions?
Users browsing this forum: No registered users and 90 guests
