DEV-thread - Blendigo v0.8 - material-editor-exporter
Post by Kram1032 » Tue May 29, 2007 8:01 am
hmmm...
here's the direct DL link
http://www2.indigorenderer.com/joomla/f ... hp?id=1001
it works fine, for me...
SimonLarsen
Post by SimonLarsen » Tue May 29, 2007 9:47 am
Kram1032 wrote:hum, I can point you to two scripts, but actually, I didn't try Dif Trans, yet :oops:
here http://www2.indigorenderer.com/joomla/f ... php?t=1997 (the post before my last, == the post before the last ;))
and
here http://www2.indigorenderer.com/joomla/f ... sc&start=0 (the 4 posts from bottom, on the first page)
Oh, didn't know about the other scripts. Thanks.
Post by Kram1032 » Tue May 29, 2007 9:01 pm
lol, ok...
mrCarnivore
Post by mrCarnivore » Wed May 30, 2007 1:06 am
In the newestblendigo 0.8 version absorbtion still doesn't work! Can anybody pls fix this problem, so I can finally use blendigo 0.8? :?
Also how far along is the material loading/saving?
SmartDen
Post by SmartDen » Wed May 30, 2007 1:39 am
mrCarnivore wrote:In the newestblendigo 0.8 version absorbtion still doesn't work! Can anybody pls fix this problem, so I can finally use blendigo 0.8? :?
Try this one. http://www2.indigorenderer.com/joomla/f ... 2302#22302
It works fine, AFAIK. Material loading/saving is not implemented yet, but it will be immediately implemented when Ono defines the igm format ;)
mrCarnivore
Post by mrCarnivore » Wed May 30, 2007 1:47 am
the .igm format was already agreed on in this thread:
http://www2.indigorenderer.com/joomla/f ... php?t=1687
I already tried the blendigo version you suggested. But to rule out any mistake on my part, I will delete all blendigo verions in my blender dir and then install that one again, to confirm this.
SmartDen
Post by SmartDen » Wed May 30, 2007 1:53 am
Ok. I try to implement it. Thanx for tip, mrCarnivore
zuegs
Post by zuegs » Wed May 30, 2007 3:08 am
@SmartDen:
I'am working on this already... perhaps a bit slow :oops:
I finalized a xml parser that seems to work fine. So i'am working currently on some GUI objects (the blender draws) that directly interacts with the materials xml data (in memory and inside the blender scene file).
Still have to solve some tricky problems...
Post by OnoSendai » Wed May 30, 2007 3:09 am
No rush Zuegs,
quality is more important than fast releases :)
Post by Kram1032 » Wed May 30, 2007 4:30 am
Exactly.
But it appears to me, that you all anyway are very fast.
I wonder, how you get this amount of Quality, in this short amount of time :shock:
joegiampaoli
Post by joegiampaoli » Thu Jun 07, 2007 6:24 pm
Anyone had this issue before with fluid sims?
Create fluid sim, export, then blender unexpectedly closes but indigo launches succesfully? Didn't happen in earlier versions of blendigo with fluid sims. :?
Joe Giampaoli
My Indigo Gallery
SmartDen
Post by SmartDen » Thu Jun 07, 2007 7:54 pm
joegiampaoli wrote:Anyone had this issue before with fluid sims?
I'll try to reproduse this crash then can i can more
tobak30
Post by tobak30 » Thu Jun 07, 2007 8:02 pm
@joegiampaoli: It seems that I have the same problem. I thought it was more of a generic trouble and not linked to the fluid sim. But as I am coming to think of it. Ity first started when I was doin my fluid sims.
joegiampaoli
Post by joegiampaoli » Thu Jun 07, 2007 8:05 pm
I mean it's really no big deal if you save your blend file before the export, but after all it's a bug, specially for those who are starting out with blender>blendigo>indigo
Thx SmartDen! Tell us what your results are.....
Joe Giampaoli
My Indigo Gallery
soxofaan
does it crash BlenderToIndigo?
Post by soxofaan » Thu Jun 07, 2007 8:56 pm
joegiampaoli wrote:I mean it's really no big deal if you save your blend file before the export, but after all it's a bug, specially for those who are starting out with blender>blendigo>indigo
Could you try to export this scene with the BlenderToIndigo exporter from http://wiki.blender.org/index.php/BlenderToIndigo (forum thread: http://www2.indigorenderer.com/joomla/f ... php?t=2037)? I wonder if it crashes with my script too. I use slightly different export procedure. If it crashes too, it is likely that the problem is not related to the exporters.
Just wondering.
