Material Thread - Post your materials here?
Arne has made a nice material web page, but until that is working properly and integrated with the Indigo site, how about posting materials here?
Thoughts?
Thoughts?
<medium>
<name>brightAmethyst</name>
<precedence>10</precedence>
<basic>
<ior>1.5533</ior>
<cauchy_b_coeff>0.013</cauchy_b_coeff>
<rgb>
<rgb>16.5 33 8.25</rgb>
</rgb>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>brightAmethyst</internal_medium_name>
</specular>
</material>
<medium>
<name>darkAmethyst</name>
<precedence>11</precedence>
<basic>
<ior>1.5533</ior>
<rgb>
<rgb>22.000000000000000000000000000011 33 10.999999999999999999999999999989</rgb>
</rgb>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>darkAmethyst</internal_medium_name>
</specular>
</material>
IoR and cbc settings are from Wikipedia, so, they should be physically correct
Edit:
The one, that's more in the background, is the "bright" Version, the one, that's more in the foreground, is the "dark" Version.
The Material-split is exactly in the middle.
Cool
Here are some materials I've made
Enjoy!
Funky Wallpaper
Texture File
Scretched Rubber
Texture File
Cola
Enjoy!
Funky Wallpaper
Texture File
<material>
<name>a</name>
<phong>
<diffuse>0 0 0</diffuse>
<nk_data>nkdata/au.nk</nk_data>
<exponent>100000</exponent>
<fresnel_scale>1</fresnel_scale>
</phong>
</material>
<material>
<name>b</name>
<phong>
<diffuse>0.3 0.1 0.1</diffuse>
<ior>1.7</ior>
<exponent>700</exponent>
</phong>
</material>
<material>
<name>materialShader</name>
<blend>
<a_name>b</a_name>
<b_name>a</b_name>
<blend_factor>0.5</blend_factor>
<blend_map>
<uv_set>default</uv_set>
<path>pattern003.jpg</path>
<exponent>1.0</exponent>
</blend_map>
</blend>
</material>scratched_rubber.jpg
Texture File
<medium>
<name>redRubber</name>
<basic>
<ior>1.4</ior>
<rgb>
<rgb>10.0 60.0 60.0</rgb>
</rgb>
</basic>
</medium>
<material>
<glossy_transparent>
<exponent>400</exponent>
<internal_medium_name>redRubber</internal_medium_name>
<bump_map>
<path>scratch_bump.jpg</path>
<exponent>0.0004</exponent>
</bump_map>
</glossy_transparent>
</material>Cola.jpg
<medium>
<name>cocaCola</name>
<basic>
<ior>1.427</ior>
<rgb>
<rgb>70.0 125.0 250.0</rgb>
</rgb>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>cocaCola</internal_medium_name>
</specular>
</material>-
SimonLarsen
Just open you xml or igs file in a texteditor and look for the name of the material there.filippo wrote:hi, I use maxigo for 3d max, I exporter the material from the material editor, but I have one file .igm.
where I found the code?
filippo
Edit: Oh, sorry, i read it like you didn't have an igm-file.
I think you can open the igm in a texteditor too.
material for LCD
!-- Exported From Maxigo 0.8.3 -->
<materialdata>
<version>0.8</version>
<medium>
<name>schermo lcd spento-medium</name>
<basic>
<ior>1.5</ior>
<rgb>
<rgb>203.0 203.0 203.0</rgb>
</rgb>
</basic>
</medium>
<material>
<name>schermo lcd spento</name>
<specular>
<transparent>false</transparent>
<internal_medium_name>schermo lcd spento-medium</internal_medium_name>
</specular>
</material>
</materialdata>
<materialdata>
<medium>
<basic>
<ior>1.5</ior>
<rgb>
</rgb>
</basic>
</medium>
<material>
<specular>
</specular>
</material>
</materialdata>
- image
- materil.jpg (10.06 KiB) Viewed 23529 times
- deltaepsylon
We should have some kind of giant XML file that we can all add materials to... but that would be kind of complex to synchronize with everyone adding materials and such. BTW in order to include external materials, u use <include><pathname>extramaterials.xml</pathname></include>, right?
Imagine maybe even a program that would connect to some server, and download updates to the materials database!
that would be pretty kewl
Edit: Can anybody post some good glass materials? for some reason, all the ones that ive used come out really weird. Like, I tried to render a cup and there were weird black regions in places. I can post a screenshot if necessary.
It's not the material, but the geometry wich has too sparse details. Subdivide the object further, these black regions are caused by Gouraud shading (I think) and objects have to be of an higher resolution to avoid this.
And... true, you can include a material database in your scenes (wer, in fact I think you can).
- deltaepsylon
Users browsing this forum: Majestic-12 [Bot] and 66 guests
