SkIndigo Progress Updates (Whaat's Development Blog)
- kwistenbiebel
Whaat,
Wow, that's great programming.
Porting a complex material setting (blended material) to a simple Sketchup option (the opacity slider). Amazing.
Very logical and pragmatical.
Ever thought of a second programming career?
You sure have the right "K.I.S.S" attitude to it (="Keep It Simple Stupid").
They should hire you to fine tune the Vray plugin for sketchup too make it more simple and efficient.
Thanks for all that candy,
Kwistenbiebel
Kwistenbiebel
Ono, Whaat!
You've just blown the bank!!!!
This transmittance feature is something the guys at NL haven't been close to cracking yet!!!!
If I'm right this material will suit very well the problem with leaves and curtains where some transmittence is justified.
Whaat:
Will this material be likely supported via the blended material ie: can we still clip the material and enable transmittance???
Brilliant stuff!!!!!!!!
Whaat:
x-ray mode
I got this idea to see if I could export Sketchup's X-ray display mode. It's maybe not the most useful feature but it might be fun to play around with. It only took me about 15 minutes to code anyway so it's not really a waste of time on my part. To export in x-ray mode....guess what? Turn on Sketchup x-ray mode!! This brilliant feature
will be in the next version of SkIndigo!
- Sketchup viewport
- carsketchup.jpg (174.2 KiB) Viewed 6047 times
- Indigo output
- carindigo.jpg (307.53 KiB) Viewed 6047 times
Well, I finally squashed the 'bug' of the Sketchup camera view zooming in or out when setting the width and height of the render. It's not really a bug, tho. I just never properly understood the relationship between the Sketchup camera model and the image aspect ratio.
Although this 'bug' wasn't much of a problem for me, I am sure some people out there (kwisten
) will be very glad to see it gone....
On another note, I don't want to give too much away, but I am working on some really cool stuff that will hopefully make it into the next version....
- kwistenbiebel
Dummy instancing
Dummy instancing test: I think the advantages of this feature are pretty obvious, especially to Sketchup users.
Number of cars: 3162
Export time: 8 seconds
Render time: approx. 30 minutes
The way it works right now is any instanced component that is named "NAME_DUMMY" will be treated as a dummy component. The actual geometry exported will be that of the component named "NAME". Make sense?
Now, I think I'll make a forest.....
EDIT: Added (really ugly) forest. Noise free in less than 30 minutes.
Cheers,
Cheers,
- Really ugly 3D trees (but you get the idea) - 30 minute render
- 3162 3D trees.jpg (171.04 KiB) Viewed 5785 times
- Sketchup viewport
- 3162 dummy cars.jpg (115.29 KiB) Viewed 5790 times
- Indigo (approx. 30 minutes)
- 3162 cars.jpg (118.69 KiB) Viewed 5793 times
