cindigo 0.8 - beta 1
Post by fused » Sun May 20, 2007 9:50 pm
yes, i think in the current version you can manually set the camera focus by editing the "focus distance" in the camera object.
and phong-breaks are kind of tricky... im thinking of a way how to do it.
the material tag will be better in the next version.
kadajawi
Post by kadajawi » Sun May 20, 2007 10:09 pm
In the camera object in C4D? I've tried that, all I've received was a very blurry image, no matter what distance I set. I haven't really compared them, so maybe there is a conversion problem, but it didn't seem to work.
Null-objects work, yay :) I guess I had a boolean somewhere in there, and that's why it failed.
My current solution that works is selecting the parts between phong breaks and putting them into seperate objects. A bit more work, but it works so far.
Anyway, thanks for the great work so far :)
manitwo
Post by manitwo » Sun May 20, 2007 10:10 pm
found one small bug:
if i give a sphere-primitive an object-tag the sphere will be exported as a mesh and indigo crashes.
Post by fused » Sun May 20, 2007 10:17 pm
thou shalt not give a sphere primitive an object tag!
but ill see what i can do
kadajawi
Post by kadajawi » Mon May 21, 2007 1:36 am
Hm, maybe a list of things that should be avoided/don't work in the first post would make sense. Maybe someone could assemble one.
Another thing I've noticed: When I use null-objects to group some objects, that works, but it doesn't care if the null-object gets rotated. The direction will stay the same.
Locked
