indigo test(who wants to participate)
12 posts • Page 1 of 1
filippo
Post by filippo » Sat May 19, 2007 6:51 am
I want made a simple test, I have made a photo to a cube.
see a image.
now I want to copy the photo with Indigo.
distance of the television camera to the fund of the cube 68cm.
I don't know the lamp.
you excuse if the model is disgusting, but I has not succeeded in doing other.
p.s.
can someone build a best model and to photograph it?
filippo
camera Iso100-expose 0 --35mm canondigital
max and 3ds file
http://d.turboupload.com/d/1805710/test_1.rar.html
image 2
esemple of result
Post by Kram1032 » Sat May 19, 2007 6:54 am
you did a real cornell box? lol
filippo
Post by filippo » Sat May 19, 2007 6:59 am
yes....
Post by Kram1032 » Sat May 19, 2007 7:11 am
hmmm...
as the internal colour of that box is white, I guess, you used the wrong whitebalance for your cam: you used sunlight or equal energy, or such, but not "A" (lamp / indoor light / ...)
filippo
Post by filippo » Sat May 19, 2007 10:54 pm
first test.....I will made a cornell box in wood, to have less imperfections
Johny
Post by Johny » Sat May 19, 2007 11:06 pm
LOL, what kind of lamp are you use for the lamp?
Post by Kram1032 » Sat May 19, 2007 11:13 pm
I guess, your tonemapping is way wrong...
the shadows are weaker, than the model ones...
paper has ~0.85 pure white, you know?
If you use wood, you also can use the correct colours :D
blue or green and red :D
And you may ask, which colour that would be EXACTLY, :D should be possible ;)
It looks quite nice and quite simmilar :D
just add a floor plane, to also get that light :D
filippo
Post by filippo » Sun May 20, 2007 3:20 am
in the next week I will made a perfect cornell box...and I buy a lanp and I post all setting of photos...this is è test..
manitwo
Post by manitwo » Sun May 20, 2007 3:21 am
cool test filippo! :D
Post by Kram1032 » Sun May 20, 2007 3:33 am
ok :D
try to get the whitebalance of your cam correct, then :D
if it's still the same lightsource, you need "indoor" or "artifical light" or such a white balance...
my camera has it called "artifical light" ;)
zsouthboy
Post by zsouthboy » Sun May 20, 2007 4:02 am
Or simply set your WB in kelvins - looks like you're shooting ~3000 degree light (incadescent) and using a sunlight wb setting (~5600 k)
Post by Kram1032 » Sun May 20, 2007 4:10 am
yes, auto-whitebalance would be a good idea, too.
