Announcements, information, requests and support regarding other exporters and general/new exporters
								Ana028
								by Ana028 » Sat Apr 28, 2007 9:08 am
			I think that lightwave is the big marginalized render software, many GNU renders engine such us indigo for example that has a lot of converters but hasn't got the lightwave version. New version of lightwave has a lot of changes (node editor, new materials) and I think that indigo would be a great render engine if an exporter for lightwave can export all new changes. Thank you.
Here is a little test of node editor.
								by Kram1032 » Sat Apr 28, 2007 10:27 am
			Ana028 wrote:..., many GNU renders engine such us indigo
Didn't know, that Indigo already is Open Source...
These pics look great!
You should contact radiance or any other Admin, to get an own forum section
																			 jay3d
								by jay3d » Fri May 18, 2007 4:18 pm
			Hi all LightWavers,
I'm here to end ur frustration!
Development begins by me on a LightWave exporter for Indigo renderer
It will be easy, integrated, powerful and even volume lights will be supported!
Complete translation of objects and materials and animation support!
cheer up! it's coming soon to ur beloved LightWave !!
								by Kram1032 » Sat May 19, 2007 4:35 am
			volume light?
you mean, you just convert the voluime light to SSS+Emitters? or what?
																			 jay3d
								by jay3d » Sat May 19, 2007 11:41 am
			Well, something like that but more sophisticated
when the exporter detects that some or more spotlight has the volumetric feature turned on it will create a bounding volume that contains the lights with the suitable mesh emitters (but the volume medium would be shared between lights at this moment), and it will count for the soft edge parameter of spotlight ...
try that on other exporters!
stay tuned
								Ana028
								by Ana028 » Sat May 19, 2007 12:22 pm
			It's a wonderful new, I'm very interested in try indigo with lw. The exporter will have node support ?
Thanks for start to make the indigo exporter for lw.
								Ana028
								by Ana028 » Tue May 29, 2007 6:27 am
			Any progress with the lw exporter ?
																			 jay3d
								by jay3d » Sat Jun 09, 2007 4:42 am
			Hi
Sorry guys for the long time, but the plugin is taking so much hard effort and work from me to make is as much as perfect and feature rich,
i'll be posting some images soon
stay tuned!
								Ana028
								by Ana028 » Sun Jun 10, 2007 12:24 am
			It's a good news that lw will has the exporter for indigo.
																			 somnis
								by somnis » Thu Jul 19, 2007 6:43 am
			Hi Jay3D,
Any news on your exporter?
Best regards,
David
																			 somnis
								by somnis » Tue Jul 24, 2007 8:25 am
Due that jay3d doesn't answer, I started my own Lightwave to Indigo exporter. I am going to calling it Magenta!
 I hope there is not problem with that!
Now, where I can find a list of all xml parameters, description and useand use? Aside the manual.
I've been looking on Blendigo script and I see that a few that the manual shows, are commented on Blendigo script, so I assume those are not valid anynmore?
Any help would be appreciated.
Best regards,
David
								Ana028
								by Ana028 » Tue Jul 24, 2007 9:03 am
			Hi Somnis, if you download the stable version of indigo 0.8. In this file there is a pdf doc with xml format. I read this pdf and I can tell to you that this pdf has information about xml.
Here is too more information about indigo.
http://www.indigorenderer.com/joomla/in ... &Itemid=69
I hope you can make an exporter for our dear lw. I think thats is the only 3d software that hasn't got an exporter.
																			 somnis
								by somnis » Tue Jul 24, 2007 8:54 pm
That is the information I am using now. But I notice for example that a parameter in that PDF:
<large_mutation_prob>0.2</large_mutation_prob> I think was this one.
It is not exported on the Blendigo exporter code. So I am asumming maybe it is because has been deprecated at some point?
Best regards,
David
								by OnoSendai » Tue Jul 24, 2007 8:56 pm
			It's not deprecated, it's just that renderer_settings elements are not compulsory, they're just for overriding values..
								Ana028
								by Ana028 » Thu Jul 26, 2007 7:27 am
			Hi Somnis, any news of the lw exporter ? I hope to test lw with this exporter.
Here is the result of the lw scene (gibox) make with Indigo. I don´t know yet how can I set up the glass surfaces and smooth meshes. But it's all right to see the result of gi. The camera position isn't in the same position because Lw hasn't got yet his exporter and I have to convert the scene to obj and test with blendigo. The scene hasn't got any light and has only a color background.
- im1185086585.png (540.75 KiB) Viewed 23400 times
