Texturing artifacts work-around
2 posts • Page 1 of 1
rgigante
Post by rgigante » Sat Sep 16, 2006 3:51 am
Hi u3dreal,
i need your help. I remember a post in the old forum where u showed a indigo rendered image with two checker-boarded sphere, the first with a wrong texturing (like the one below) the second with a perfect one. If i'm wrong it dealt with a texturing issue related to implicit texturing
http://img61.imageshack.us/img61/4650/t ... ctskr5.jpg
Although the exporter (XSI2Indigo) i'm working on, exports correctly explicit-texture coords (through the use of CGeometricAccessor) i dunno how (or at least IF) could be exported implicit-ones because i don't know if implicit texturing is done at the render-engine level (MentalRay takes care of) or not.
Thanks for sharing any hint you used in your exporter.
Regards, Riccardo
u3dreal
Post by u3dreal » Sat Sep 16, 2006 6:14 am
Hmm i have no idea how that works in XSI...
the problem was that there were more textureverts than objectvers...
so i duplicated every objectvert that has two or more textverts...
if you have 3 different textverts then you have to get three objectverts..
i have no idea if this only applies in max or in general... but that is the
difference between max and 3ds...
hope that helped
u3dreal ;)
Users browsing this forum: No registered users and 71 guests
