cindigo 0.8 - beta 1
Behrendt
Post by Behrendt » Mon May 14, 2007 5:30 am
Would this work with the map you provided in the scene? Because it doesn't work for me atm. :oops: Also tried blend values of 0 and 1.
Thanks for your work! Makes such a lot fun to play around with it! :)
edit:
f*ck, blend material in sample scene doesn't works either, sphere dissapears completely. but diffuse transmitter works fine. maybe a little overbrighted, compares to your screenshot.
Post by fused » Mon May 14, 2007 5:46 am
must be a bug. ill check it
Pinko5
Post by Pinko5 » Mon May 14, 2007 5:46 am
Tnx Fused great work!!!
Pinko.
Post by fused » Mon May 14, 2007 5:53 am
@Behrendt:
it works fine for me. heres a sample scene (maybe you forgot the object tag?)
alpha2.zip
(32.01 KiB) Downloaded 313 times
Behrendt
Post by Behrendt » Mon May 14, 2007 5:58 am
fused wrote:@Behrendt:
Oooops, yes I did. Thought you did this in sample scene. :oops:
Camox
Post by Camox » Mon May 14, 2007 6:40 am
Hi fused, thanks again for your hard work and your great exporter !
I have a mapping problem with the new exporters.
export with 0.75 and renderet with indigo_08.t3
export with cindigo_0.8b1.3 and renderet with indigo_08.t3
normal smoothing looks fine but textur mapping is not really working.
I read all tutorials but i cant finde the mistake, the result is ever the same.
greetz :wink:
Post by fused » Mon May 14, 2007 6:45 am
only uvw-mapping is working. for now.
if you use uvw-mapping: can you send me the scene?
Camox
Post by Camox » Mon May 14, 2007 6:55 am
fused wrote:only uvw-mapping is working. for now.
Why you write that not in your exporter list ? That suckt really :?
Post by fused » Mon May 14, 2007 6:58 am
sry, forgot that :oops:
im having a look at what the c4d sdk documentation says about that right now. will work on that
edit:
looks complicated :P
case P_SPHERICAL: default:
        Vector d = p * tdp->im;
        Real sq = Sqrt(d.x*d.x + d.z*d.z);
        if (sq==0.0)
          uv->x = 0.0;
          if (d.y>0.0)
            uv->y = +0.5;
          else
            uv->y = -0.5;
        else
          uv->x = ACos(d.x/sq)/pi2;
          if (d.z<0.0) uv->x = 1.0-uv->x;
          uv->x -= tdp->ox;
          if (tdp->lenx>0.0 && uv->x<0.0)
            uv->x += 1.0;
          else if (tdp->lenx<0.0 && uv->x>0.0)
            uv->x -= 1.0;
          uv->x *= lenxinv;
          uv->y = ATan(d.y/sq)/pi;
        uv->y = -(uv->y+tdp->oy)*lenyinv;
        break;
Camox
Post by Camox » Mon May 14, 2007 7:03 am
lol, no problem. I think that mapping problem is my mistake and try and try. UVW mapping works fine. :wink:
Camox
Post by Camox » Mon May 14, 2007 7:09 am
fused wrote: looks complicated :P
        if (sq==0.0)
          uv->x = 0.0;
          if (d.y>0.0)
            uv->y = +0.5;
          else
            uv->y = -0.5;
        else
          uv->x -= tdp->ox;
            uv->x += 1.0;
            uv->x -= 1.0;
          uv->x *= lenxinv;
        break;
:shock: :shock:
thats not for me.
echo" 1+1=2" :roll:
Post by Zom-B » Mon May 14, 2007 7:33 am
damn it, you have to be insane to understand this :twisted:
My HTML & ActionScript Skills can't harm this beast :wink:
Post by Kram1032 » Mon May 14, 2007 8:43 am
why?
not really...
give me... 1 year, and I can tell you, what that means :P
no... I guess, a week (24h/day 7d) would be enough xD
Marcofly
Post by Marcofly » Mon May 14, 2007 9:52 am
the translation is: be happy that you can use "only" uvw mapping, instead of editing the .igs by hand every time :wink:
give fused time: he is giving his best..
Thanks again!!
Marco
Post by fused » Mon May 14, 2007 7:10 pm
thats right, you should be happy with what im giving you :?
whatever.
i have strange arifacts on my renders (again) and i still dont know where they are coming from. does anybody of you have similar problems? its a phong material and normal_smoothin = false.
is this problem caused by my exporter or by indigo?
strange artifacts...
Locked
Users browsing this forum: DotBot [Bot] and 33 guests
