Using an exr image in sketchup
Richard
Post by Richard » Wed May 09, 2007 9:21 pm
Peter how did you do that water if you don't mind me asking????? Looks great!!!
peer
Post by peer » Thu May 10, 2007 8:11 pm
The water is a plane that is crumpled ( I modelled it in Cheetah3d than exported it as an 3ds file.) The material is a standard glass material. There's no thickness, but I didn't need the refraction.
The plane has lots of polygons, but I'll try to post the .skp file when I get back to work.
edit: OK. Here's the FILE
Regards,
Peter
Mac Pro 3GHz quadcore, iMac dualcore 2 GHz, Vectorworks 2008, Sketchup 7 Pro, Indigo Renderer, Cheetah3d 4.6.3, OS X 10.5.6
2kemon
Post by 2kemon » Thu May 10, 2007 8:33 pm
Hi Peer
Great looking water! Do you think a decent bump map to single plane glass material would be able to create a similar effect?
It would probably create a much calmer water, but i guess that would work fine in most cases?
Post by Kram1032 » Fri May 11, 2007 1:36 am
as long as your angle of sight isn't too flat, It should give the same result...
if it doesn't have thickness, it can't be a glass material... it must have IoR 1
2kemon
Post by 2kemon » Fri May 11, 2007 1:50 am
...I'm guessing a single plane specular material would take less time to render than a specular with thickness and IOR. I'm also guessing water with thickness would look more realistic?
Post by Kram1032 » Fri May 11, 2007 2:02 am
hmm... about Speed: I'm not surte about that...
about relism: definately.
IoR 1 more or less means invisibility, btw... it then is Air, more or less...
actually, it's vacuum :lol:
Richard
Post by Richard » Fri May 11, 2007 1:53 pm
Thank you Peter!!!!!!!
I tried pool water with a bump map and for most shots the veiwing angle was too low and the water just looked blotchy. That was using glass with thickness!
We need some smart cookie to devise a way to surface water and windows with a single plane material to avoid the refractive and time consumption that glass can lead to!
Cheers all!!! Richard
