cindigo 0.8 - beta 1
Locked
Marcofly
Post by Marcofly » Wed May 09, 2007 7:14 am
now it´s working again..
i remodeled the scene in c4d (the first was a .3ds object imported in c4d.
quick glossy transparent test.
Post by Kram1032 » Wed May 09, 2007 7:49 am
hey, that looks nice :D
Post by fused » Wed May 09, 2007 8:47 am
@marcofly: that looked really strange.
what was the reason for that?
nice test
Marcofly
Post by Marcofly » Wed May 09, 2007 9:32 am
thank you!! :D
i notice always some strange behaviour when i import to c4d and export to indigo.. rotation, scale, smoothing problems. if i create the object directly in c4d everything is ok! i don´t know..
i´m getting a core2duo tomorrow: i am going to test further, and QUICKER!! :wink:
ciao!
Post by fused » Wed May 09, 2007 9:40 am
argh... im so jealous... i want one, too (or two :P)
im fixing the rotation and crashing bugs right now. there will be another release very soon :)
Post by fused » Wed May 09, 2007 10:01 am
im sorry... that texture mapping bug seems to be much more complicated than i thougt before.
ill have to rewrite parts of my obj export. this could take longer and i wont do it today.
Post by fused » Wed May 09, 2007 10:58 am
forget it. i couldnt sleep, so here it is
CINDIGO 0.8 - BETA 1.2
download exporter here (or below)
The file PC versions for R10 and R9. (R10 users will have to rename the "cindigo0.8.1.cdl_R10" to "cindigo0.8.1.cdl")
Mac version will follow soonish.
new in 0.8 - beta 1.2:
* have a look at the console after exporting, it prints errors! :)
fixed-list 0.8 - beta 1.2:
* texture mapping bug
* not crashing anymore when there is no uvw tag or a material link not set
known bugs/issues 0.8 - beta 1.2:
* sometimes you have to guess the right fields, didnt find out how to hide them yet
* normal problem with .3ds export (=> .3ds export disabled)
* normalization of Vertex Normals is disabled(doesnt work properly), indigo will do that for now :) (and it takes very very long)
please post bugs :!: :!:
a good tutorial can be found here (only german and italian, hope someone will translate it to english soon).
still no sample scene
Cindigo 0.8.zip
CINDIGO 0.8 beta 1.2
(262.58 KiB) Downloaded 288 times
Behrendt
Post by Behrendt » Wed May 09, 2007 12:45 pm
Hello! :D
I downloaded the exporter and done the steps you described in your tutorial. But when I run the start.bat Indigo opens with the Message "could not open inifile.txt" but inifile.txt is definetly in the indigo directory :(
I use Indigo 0.82 and Cinema4dR10
edit:
works fine if i start indigo.exe directly
one bug i think i found is:
primitives of c4d don't work properly! cubes for example i have to convert to polygon object. spheres not.
when i try to use specular materials i get a "fatal error" look at attachment
but probably only my fault. can someone explain to me how to make reflective materials or glas? :oops:
Post by fused » Wed May 09, 2007 5:09 pm
indigo does only suppoert sphere primitives and planes.
in the material settings you have to check "export internal medium" then it should work fine.
and you cant open a scene over command line any more (or start.bat)
Phoenix
Post by Phoenix » Wed May 09, 2007 7:07 pm
fused wrote:... and you cant open a scene over command line any more (or start.bat)
Why that?
How does network rendering work now?
Or did I get something wrong?
Marcofly
Post by Marcofly » Wed May 09, 2007 9:31 pm
thanks fused!!
a ´grassy´test with the new exporter.. :lol:
Post by fused » Wed May 09, 2007 9:42 pm
WOW :shock: ... how did you do that???
did you use hair?
Micha1138
Post by Micha1138 » Wed May 09, 2007 9:54 pm
Marco, that´s awesome !
Please tell us how you did that ! Don´t make me jump into the car and drive all the way to Cologne to get the secret out of you by force ! (It´s just a fifteen minute drive from the north down, but with all that rain coming down at the moment, I´d rather not step out of the house ;) )
But more important, as usual the important infos are missing, i.e. cpu and memory setup and render time.
I just yesterday found out what nifty things can be done with place on points and repititions, but I was too hesitant to be so bold an test a poly heavy scene with Indigo. But now, I might just do that !
Michael
Post by fused » Wed May 09, 2007 9:57 pm
yeah, do that! :)
Behrendt
Post by Behrendt » Wed May 09, 2007 10:06 pm
Now i checked "export internal medium" and I don't get this error-message. But my transparent material has no IOR, but I set the IOR value to 1,5 in the "external medium" options. And the material has no reflection either :( Can somebody help me or share material settings? :oops: (Indigo 0.4 was way easier :P :P )
Locked
