Well, I've got the sensation that textures are not visibles backface, Suvakas, what's happening really ? Yes or no ?
Very interesting these blends
Blend inside blend is actually one material that has been constructed using multiple blends. How would you like to export blend then? Each blend element as a separate igm file? How can the end user put it together afterwards?Wedge wrote: According to the radiance thread, it looks like one igm equals one material. So if nested blends is what I think it is, how can it be an igm file? Wouldn't it be one igm file per material?
That's correct. Doesn't your exporter support this already? Is it limited only to one blend?Wedge wrote: nested sounds like: blend, mat a blend (leading to another blend, mat a, mat b), and mat b or mat b blend (leading to another blend, mat a, mat b)
<uv_set>-none-</uv_set>
