cindigo 0.8 - beta 1
Post by fused » Mon May 07, 2007 9:07 pm
in your scene its the same old "material link is not set, exporter crashes" problem.
ill check if its set or not to stop the crashing
Post by Zom-B » Mon May 07, 2007 9:09 pm
The 3DS Export stuff is based on your older exporter for 0.7t5.
About the bump size, thats no real big problem :wink:
Post by Zom-B » Mon May 07, 2007 9:12 pm
fused wrote:in your scene its the same old "material link is not set, exporter crashes" problem.
oh.... I fell stupid!!!
Pinko5
Post by Pinko5 » Mon May 07, 2007 9:13 pm
but where i can disable 3ds export....maybe my crash is due to this thing.
Pinko.
PS: Excuse me but i am not expert like you...
rulze
Post by rulze » Mon May 07, 2007 9:15 pm
ok, i'm not really a indigo checker, but one scene works and the other crashed when i will exported.
http://3dwork.ch/indigo_work.rar
lg
rulze
Pinko5
Post by Pinko5 » Mon May 07, 2007 9:28 pm
ok rulze also for me is the same .....but i dont undestand why...
Pinko. :cry:
Post by Zom-B » Mon May 07, 2007 9:45 pm
Here is another Scene that crashes... before it does, it exports a OBJ file without any mesh?!
Post by fused » Mon May 07, 2007 9:46 pm
rulze: wow, thats a mysterium... cant debug the exporter here, but ill do that when i get home. thanks for the scene!
Post by fused » Mon May 07, 2007 9:49 pm
no, its no myterium. before export you have to generate a UVW tag for every object that has no UVW tag
@rulze: your scene exports fine after doing that
Pinko5
Post by Pinko5 » Mon May 07, 2007 10:30 pm
Ok before UVW tag the exporter dont crash...but now I see all meshes are round like there was a phong tag... :( and some object are rotate like as made created
Pinko.
rulze
Post by rulze » Mon May 07, 2007 10:36 pm
oh thanks, now it works finde, i don't know that, with the vvw tag.
lg
rulze
Post by Zom-B » Mon May 07, 2007 10:37 pm
Hey Pinko...
Normal smoothing is enabled in the Exporter now, so you have to disable it for meshes you don't wan't to be smoothed!
Please post a reduced scene, where your objects get exported rotated, so fused can take a look at :wink:
Pinko5
Post by Pinko5 » Mon May 07, 2007 10:57 pm
@ ZomB I must send a C4d scene or my igs???
Marcofly
Post by Marcofly » Mon May 07, 2007 11:22 pm
thank you very much, fused! :D
it´s working fine for me, the basic test below is with an interior .exr lighting, about 400 muts/pixel, MLT.
ciao!!
Post by Zom-B » Tue May 08, 2007 12:00 am
@ Pinko: A C4D file, to check out what exactly is going on there...
atm I have issues with rotation stuff too, seems there are problems if you
move nullobjects that includes meshes you are exporting...
(I often put my whole scene in a Null-Object, and rotate it to get another part of the HDRI for background in Indigo)
I also just get some texture coordinates Export Problems:
Here is the full scene with textures (no HDRI)
Locked
