Indigo Exporter for 0.7t5 - beta release
Post by Kram1032 » Tue May 01, 2007 10:46 pm
O.o
Edgy spheres are nice!!!
Post by fused » Wed May 02, 2007 12:39 am
...yes they are edgy... but they are smoothed, too :)
Post by Kram1032 » Wed May 02, 2007 12:51 am
have you tried to use´
a) higher poly?
b) if they are not textured: primitives?
looks great, though ;)
Post by fused » Wed May 02, 2007 12:59 am
guess you dont get the point...
this test shows that i finally solved the normal problem.
your suggestions:
a) nobody would see that they are no primitves
b) wouldnt be exciting at all
Post by Kram1032 » Wed May 02, 2007 1:02 am
oh, ok :shock:
sorry... I should read through the exporter bugs, when I'm writing in an "alien" exporter-forum :?
Post by fused » Wed May 02, 2007 1:04 am
no problem :)
Phoenix
Post by Phoenix » Wed May 02, 2007 1:41 am
fused wrote:here is something i dont want to hide from you ;)
edit: procedural tut coming with the next version.
Hey great, it seems that you found a solution for the normal-smoothing problem! :D
When will the next release be available? 8)
Edit:
Oh It doesn't seems so, in fact you even mentioned it meanwihle!
I should form a habit of reading all the following posts too, before posting myself. :?
Post by fused » Wed May 02, 2007 2:00 am
i also found a solution for the string conversion, so if everything works out the way i want there will be a Cindigo 0.8.1 beta 1 at the end of the day :)
Post by Zom-B » Wed May 02, 2007 7:51 am
sounds great, I had some C4D crasing issues with the last release...
I'll wait for the next one to post my (small) "buglist".
Post by fused » Wed May 02, 2007 10:42 pm
for everyone looking for a new version of the exporter for 0.7:
the 0.8 exporter works fine with indigo 0.7 final.
please dont post here anymore so evryone looking for a 0.7 exporter can see this!
Locked
