This should not be Maxigo's problem.
Maxigo only "shows" to indigo what *.exr file to use. If indigo crashes, then it is Indigo issue.
Lets hope that Ono will check it out.
[edit] I did some tests and exr is working fine for me in 08t1. Doesn't mather if hybrid is on or off, works fine with both.
the last exporter don't work with indigo 0.8
- Kosmokrator
Eh..i got it to crash
Indigo 08t1 crashes every time when i use Bidir with exr image. Every single time. If I turn off Bidir, then it renders fine.
Hey Kosmo, can you render exr with bidir enabled?
Currently it seems, that the best setting for rendering exr image in 08t1 is to use Pathtrace only. Leave Bidir and Hybrid off. At least for me it gives the best results and with less noise than other methods.
- Kosmokrator
yes renders fine.......but some times gives me total black images....i dont know somethinf is wrong with 0.8
Ono says there is some bug with bump...i confirm this....when i disable any bump renders cool w/wo hybrid or bidir!
i dont know about exrs problem...for me its ok!
