CG Sphere project - 'Spherahedrons'
Post by CTZn » Sun Apr 22, 2007 4:39 am
maybe try a lower rotational speed, so the bottom of the swirl would be closed (at least much thinner), it's not really obvious it's a swirl right now... other than that, rendering and baking resolution look ok to me :)
Edit: btw, blender's fluid sim looks amazingly stable :shock:
Lord of the Rings Junkie
Post by Lord of the Rings Junkie » Sun Apr 22, 2007 10:32 am
Ok, I'll try a bit slower rotation once I get my new system up and running. Hopefully it should bake much faster than it did with the old RAM.
Post by Kram1032 » Sun Apr 22, 2007 10:35 am
and you may will be able to bske even higher resolutions :D
Post by Lord of the Rings Junkie » Fri Apr 27, 2007 1:13 am
w00t! I have my new system! :D I did a 4000 x 4000 Blender Internal render of a model with about 0.6 M polys, and it shaved 10 minutes off of the render time on my old 2.4 Ghz P4! :shock: I'm getting the wireless internet set up later today, so Indigo tests are still to come.
[Edit] I'm doing a week long dogsitting job in May that will give me enough money to buy this case. Should keep my CPU icy cool! :twisted:
Post by Lord of the Rings Junkie » Sat Apr 28, 2007 3:19 pm
Okay, I'm baking at res 75 right now. If it's successful, tomorrow night I'll try res 80. I'll keep going in increments of 5 until the simulation fails.
Post by Kram1032 » Sun Apr 29, 2007 3:50 am
great :D
100res :D :D
Post by Lord of the Rings Junkie » Sun Apr 29, 2007 3:22 pm
Bake successful, gonna try res 80 tonight.
.avi 5 MB
Sorry for the slightly larger video than last time, I haven't installed Xvid again on my computer yet. Compression is avi jpeg.
Post by CTZn » Sun Apr 29, 2007 3:35 pm
Oookaaay !!! Try to get a balance between resolution and speed of motion, I understand you are testing your system but realisation is about -compromises-
Go the higher you can, then step back !
My 2 (two) cents.
Post by Lord of the Rings Junkie » Sun Apr 29, 2007 5:25 pm
Yes, it is a huge compromise, I realize that. If I had my way, I would make it 250 resolution. I'm just trying to see how much resolution I absolutely have to give up to make a vortex. I'll also see how much speed I can give up and keep a vortex.
Post by Kram1032 » Sun Apr 29, 2007 8:11 pm
great :D
But I think, it should be highest possible, none the less, as long, as the geometry can still be loaded in indigo.
when you already get a HUGE resolution, you also should try to build a kd-tree... It may stop 'cause the kd-tree has a timeout.
