How to make illuminated textures (blendigo)
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
15 posts • Page 1 of 1
DaveC
Post by DaveC » Fri Apr 20, 2007 11:15 am
This is my first attempt at a tutorial and it's in pdf format (sorry). I used my illuminated advert to illustrate how to get around the problem of light emitting textures. It's not ideal for every situation, but it sure works. The tutorial requires blendigo but I'm sure the material methods are suitable for all indigo users.
brightads_tutorial.zip
(3.81 MiB) Downloaded 1396 times
crsrma
Post by crsrma » Fri Apr 20, 2007 1:06 pm
Very nice attempt, it's also a great explanation of blend materials. Thanks. :)
mrCarnivore
Post by mrCarnivore » Fri Apr 20, 2007 7:28 pm
Nice tutorial, but why don't you use uniform sss, when you use the same values for every colour? Should be much faster.
Also, why do you have to use sss at all? Youdon't need it to scatter the light, since you didn't model the tubes but an already uniformly lit surface...
DaveC
Post by DaveC » Fri Apr 20, 2007 8:12 pm
@carnivore.
Try it without SSS and see what happens. ;)
mrCarnivore
Post by mrCarnivore » Fri Apr 20, 2007 9:14 pm
I will try tonight. However, you should still use uniform sss. :P
DaveC
Post by DaveC » Fri Apr 20, 2007 9:23 pm
it makes no difference. Uniform SSS is just RGB SSS with R, G, and B all at the same value. With RGB SSS you can control the colour of the scattering. That is the only difference.
Post by OnoSendai » Fri Apr 20, 2007 9:44 pm
Thanks Dave.
DaveC
Post by DaveC » Fri Apr 20, 2007 10:13 pm
No problem, Nick. I will look at the Wiki if you like to see if I can put this in the right format.
Post by OnoSendai » Fri Apr 20, 2007 10:15 pm
Perhaps u could add a link to the download on the wiki.
mrCarnivore
Post by mrCarnivore » Sat Apr 21, 2007 12:55 am
DaveC wrote:it makes no difference. Uniform SSS is just RGB SSS with R, G, and B all at the same value. With RGB SSS you can control the colour of the scattering. That is the only difference.
It DOES make a difference. rgb sss with same colours takes WAY longer than uniform sss!
DaveC
Post by DaveC » Sat Apr 21, 2007 1:18 am
mrCarnivore wrote:It DOES make a difference. rgb sss with same colours takes WAY longer than uniform sss!
Ok, then, ermm..., I WANTED to use coloured sss ;) But if you want a quicker render, people, use uniform sss ala mrCarnivore's advice. 8)
kwez
Post by kwez » Sun Jan 20, 2008 6:38 pm
I just tried this tutorial, very nice, thank you.
but I just get a black image !
Blender 2.45
Indigo 1.0.5
Blendigo 1.0.4
I cant get the blend material (poster+clear) to let any light through !
if I remove the 'poster', I do get light
(I checked the normal of the light obj, it points 'outside' the enclosure)
if I place a light source outside, I do see the poster..
I tried using 'null' material for 2nd blend value ..
in this case, I dont see the image at all...
any hints ?
thx
Philippe
Post by Kram1032 » Mon Jan 21, 2008 12:00 am
kwez, this isn't necessary, any more: Indigo now has textured emitters ;)
kwez
Post by kwez » Mon Jan 21, 2008 10:03 am
ah !
that was easy.
10secs fix ;-)
cool thx !
Post by Kram1032 » Mon Jan 21, 2008 10:25 am
no problem :)
looks nice!
