nakile
by nakile » Sat Apr 07, 2007 1:52 pm
What's the command? I know it can be done, but I don't see it documented anywhere.
by Kram1032 » Sat Apr 07, 2007 8:44 pm
-r ____.igi
as far as I know...
But I never did it, yet... try it yourself, or wait for other posts
DaveC
by DaveC » Sat Apr 07, 2007 8:53 pm
indigo (name of xml file here) -r (name of igi file here)
make sure you're in the right path or you type the correct path for the necessary files.
nakile
by nakile » Sun Apr 08, 2007 9:24 am
Heh, worked great! Took right off from last time.
I might use Indigo a little more now.
by CTZn » Sun Apr 08, 2007 4:36 pm
AFAIK you can reverse the order of the two terms of the command, doesn't matter. Just a lil' tip.
DaveC
by DaveC » Sun Apr 08, 2007 11:36 pm
yes CTZn, you're quite right. as long as the correct information comes after its corresponding switch, everything should work.
by StompinTom » Mon Apr 09, 2007 8:01 am
what about windows? is there a way to do it from the GUI or is that planned for the next release?
crc
by crc » Fri Apr 13, 2007 9:21 am
in Indigo 7 I am getting an igi file and an igs files. I'm guessing the igs file replaces the xml? Seemed to work for networking, wish I had read this post earlier, would definitely have saved me some render time.
Olis
by Olis » Fri May 04, 2007 8:21 am
DaveC wrote:indigo (name of xml file here) -r (name of igi file here)
Where do you write that command?
DaveC
by DaveC » Fri May 04, 2007 8:28 am
You need to open a cmd window. Go to the start button and select Run. Enter cmd and press enter. Now you can run indigo by typing the command.
by CTZn » Fri May 04, 2007 8:41 am
or write it to a text file and rename file type to *.bat, save and double-click.
Olis
by Olis » Fri May 04, 2007 8:55 am
Thanks for the fast replies!
Olis
by Olis » Fri May 04, 2007 9:13 am
When I write what you said in cmd, I get a fatal error saying:
- indigo error.png (604 Bytes) Viewed 13118 times
by CTZn » Fri May 04, 2007 9:50 am
type full paths for the three terms
