Indigo for Cinema 4D 4.4.13.1
wob
Re: Indigo for Cinema 4D 4.4.13.1
Post by wob » Thu Dec 24, 2020 11:51 pm
this is only the way to get right focus with cindigo exporter > standalone app (changing focus object with keyframes, with indigo compositing tag > invisible object):
focusbug_correction.zip
(35.06 KiB) Downloaded 1361 times
Post by zeitmeister » Fri Dec 25, 2020 10:11 pm
Now I've got your point!
Indeed focus object distance is not being exported correctly for animations when linked in the camera options... in R20 here.
Seems like values are not being read by Cindigo or, what I presume, written at render time properly by C4D.
Because it does work in IPR and VIPR.
But there's no need for keyframes: just use my little expresso thingy; it should work.
If you use a null object as focus target, there’s no need for hiding it via indigo compositing tag also.
Check it out!
focusbug_with_spikes_expresso.zip
(56.06 KiB) Downloaded 1250 times
wob
Post by wob » Sun Dec 27, 2020 8:14 am
Check it out!
okey thanks!
wob
Post by wob » Mon Dec 28, 2020 1:27 pm
why does cindigo exporter works only with absolute file pathes? can you add "exporting with relative pathes" function in igs/igq? i have to change in manual mode via notepad++ "c:\\" pathes on laptop to "\\networknameofmaschine\\" if i want to open igq/igs on home tower pc.
Post by zeitmeister » Mon Dec 28, 2020 11:01 pm
Yeah it should be optional.
In the meantime you could pack a PIGQ or PIGS from the standalone, take it to another machine and open it there.
Post by pixie » Tue Dec 29, 2020 12:51 am
damn zeitmeister, you seem to have solution for everything! xD Happy holidays
Post by zeitmeister » Tue Dec 29, 2020 6:07 am
Erm no... but spare time. ^^
Happy holidays!
wob
Post by wob » Tue Dec 29, 2020 8:53 am
no, i can't (look to the scene folder size):
wob
Post by wob » Tue Dec 29, 2020 8:54 am
Check it out!
thanks, will try.
Post by zeitmeister » Tue Dec 29, 2020 11:55 pm
Sorry, my Russian is a bit non-existent.
PIGS will compress the files. You tried to open indigo standalone, choose „Tools“, and then „Pack Indigo Scene/Queue/Material“?
What filesize do you get in result?
wob
Post by wob » Thu Dec 31, 2020 12:55 am
it was a screenshot of 130Gb scene folder with 55000 files.
Post by zeitmeister » Thu Dec 31, 2020 5:12 am
... and compressed as pigs?
wob
Post by wob » Thu Dec 31, 2020 1:45 pm
120Gb
Post by zeitmeister » Thu Dec 31, 2020 7:53 pm
You made me curios.
So if you can’t transfer that pigs the only way remains editing the filepaths externally.
But as I said, it should definitely be an option.
wob
Post by wob » Fri Jan 01, 2021 1:57 am
You made me curios.
i just change file pathes in Notepad++'s batch mode from "c:\\" to ""\\mylaptoppc\", then it's possible to open the igq scene via local network on my rtxs tower pc via Windows Explorer. but it's a trick, not a normal exporter's function.
Users browsing this forum: No registered users and 101 guests
