Translation for the upcoming (pretty much done) Material DB
This forum is for discussing the Indigo Website, The community, its organization and the online tools/resources.
arneoog
Post by arneoog » Wed Apr 04, 2007 4:48 am
Everything is ready for the final translation of the language file for the Indigo Material DB :D
It is one file with words and sentences to translate.
Example:
DEFINE('_HELLO','Hello'); //Hello, user...
What you're going to translate is the content of the second ''
The above example will be, in German:
DEFINE('_HELLO','Hallo'); //Hello, user...
Here is a link to the matDB test version in english Click Here
I hope that helps you translate most of the things right :P
If you want to translate it into your language,
post a reply saying that you're going to translate, and also which language you'll translate it into :)
Hopefully the small comments after some of the things to translate will help you get it right.
When you're done, name it (e.g. de.php , if it's German) zip it and upload it here ;)
I don't care how many languages it'll be translated into 8)
But all of them will be included!
Happy Translating! :lol: :D :wink:
en.zip
The zip file containing the file to translate :)
(1.23 KiB) Downloaded 328 times
Post by Kram1032 » Wed Apr 04, 2007 4:49 am
I'll do the german translation :mrgreen:
Edit: here it is :D
de.zip
German translation
(1.36 KiB) Downloaded 250 times
joegiampaoli
Post by joegiampaoli » Wed Apr 04, 2007 12:56 pm
Ok, I'll do the spanish translation, just a question at the top of the file you have.....
<?PHP
//INDIGO MATERIAL DB---//
//en.php---------------//
//LANGUAGE: ENGLISH----//
//BY ARNE OOG----------//
Should this change to:
<?PHP
//es.php---------------//
//LANGUAGE: SPANISH (or ESPAÑOL)----//
will leave that intact, meanwhile will do the rest.....
EDIT: Ok I did change that info based on Kram1032's file and here is the translation, I will have to see the file in action to check that words apply as they should, if not I will make an edit and repost it and let you know about any changes.
es.zip
(1.35 KiB) Downloaded 293 times
Joe Giampaoli
My Indigo Gallery
Post by CTZn » Wed Apr 04, 2007 12:59 pm
In PHP, is " the same as ' ? Because French use ' a lot, so where it was needed in the sentence I used " as a separator, I hope that's correct. If not I'll leave a blank space.
And depending of the context the file may need some corrections, sometimes I'm not sure (mostly for _APP_S_MAT1 and _APP_S_MAT2). I'll know when I'll see it in action.
Now to french people:
J'ai utilisé le mot "matériau", dites-moi si vous préférez "matière". Lequel utilisez-vous le plus ?
fr.zip
French Translation v.1
(1.42 KiB) Downloaded 264 times
mrCarnivore
Post by mrCarnivore » Wed Apr 04, 2007 7:41 pm
I tweaked the German translation from Kram a little bit. Sometimes he used awkward translations...
@Kram1032: Could you please check my translation and give your OK, if you agree with the changes I made!
de.zip
Corrected German translation
(1.38 KiB) Downloaded 272 times
GNUdo
Post by GNUdo » Wed Apr 04, 2007 8:44 pm
Here it is the Italian translation.
When it will be online I'll see if it needs to be modified.
it.zip
Italian translation
(1.4 KiB) Downloaded 286 times
Post by Kram1032 » Wed Apr 04, 2007 10:13 pm
Ok, new Version :D
A little mistake in our both Versions, that I found and corrected ;)
de.zip
Hopefully the lastest german Version, thx MrCarnivore :D
(1.39 KiB) Downloaded 270 times
arneoog
Post by arneoog » Wed Apr 04, 2007 10:30 pm
Wow :shock: :D
Thank you :P
Well, I'll post some links to the matDB test version :)
English, Deutsch, Français, Español, Italiano, Norsk
Please chack if most of the translations fits, just surf through everything you can...
Some places are "off-limit" but the translation in those places are very much straight forward.
...should have posted this in the first post.. heh ;)
Oh well.. Cheers!
Stur
Post by Stur » Thu Apr 05, 2007 12:09 am
CTZn wrote: Now to french people:
J'avais commencé à le traduire cette nuit, mais à cause des problèmes de contexte j'ai mis de côté. J'avais utilisé "Matériau" aussi, et sur le reste tu t'en es très bien sorti. Impec :)
GNUdo
Post by GNUdo » Thu Apr 05, 2007 1:07 am
Italian translation corrected.
it.zip
(1.4 KiB) Downloaded 259 times
paulo_gomes
Post by paulo_gomes » Thu Apr 05, 2007 3:17 am
ok, here is my Portuguese translation.
pt.zip
(1.32 KiB) Downloaded 279 times
Post by Kram1032 » Thu Apr 05, 2007 3:40 am
Just found a very small mistake :? , again..... :oops:
It's just a single word, but it makes difference... :o
Please update once more :)
de.zip
updated german
(1.39 KiB) Downloaded 269 times
Post by CTZn » Thu Apr 05, 2007 3:43 am
Merci Stur !
This one is ok, as far as I could check. Maybe when we will be able to log on it'll need a new update tho...
Nice job Arne ;)
fr_v2.zip
French Translation, Version 2.
(1.44 KiB) Downloaded 270 times
arneoog
Post by arneoog » Sat Apr 07, 2007 8:39 am
Ah, thanks for translating :D
Everything is added, and actually done! :shock:
This meaning that, yes, the matDB is done! For my part.. almost.. :)
Everything is sent to radiance, and now he (and I) are going to embed it into this site ;)
I can not say when it will be done and ready for full use, but it shouldn't be to far away now! 8)
I will make a v2.0 also, starting as soon as possible :P
Cheers!
DaveC
Post by DaveC » Sat Apr 07, 2007 9:04 am
Three cheers for Arne!
Hip Hip Hooray...
Hip Hip Hooray...
Hip Hip Hooray!!!!
