Panorama
11 posts • Page 1 of 1
rikokun
Panorama
Post by rikokun » Fri Mar 23, 2007 11:23 pm
Hi. Just wanted to ask, is there a way to render 360 degrees panorama image in indigo?
SmartDen
Post by SmartDen » Fri Mar 23, 2007 11:28 pm
take >6 pictures around camera and stitch those together ;)
rikokun
Post by rikokun » Fri Mar 23, 2007 11:50 pm
yeah, this solution also crossed my mind, but i wanted to know if there is some better solution ^_^
mrCarnivore
Post by mrCarnivore » Sat Mar 24, 2007 12:03 am
It depends in what format you want the render.
If you want it latlong I would suggest that you use the method SmartDen proposed.
rikokun
Post by rikokun » Wed Mar 28, 2007 12:29 am
Ok, so now we have rejected the idea of rendering one panoramic image. Instead i woul'd need 6 pictures to map on cube. BUT i need to have field of view exactly 90 degrees. Is there a way to set up this? Didn't find it in xlm.
mrCarnivore
Post by mrCarnivore » Wed Mar 28, 2007 1:14 am
If you use blender, there is a nice script for exactly that purpoase that does all the work for you:
http://www.alienhelpdesk.com/index.php?id=16
Don't know how much you will have to tweak it to work with the exporter or blendigo, though...
Post by Kram1032 » Wed Mar 28, 2007 5:34 am
I somewhere read a formula to calculate the stuff...
Don't know, where, though...
I think, it was something like " 2*tan(value)=angle "
Post by CTZn » Wed Mar 28, 2007 7:02 am
Hey that topic is interesting, producing hdr panoramics would be cooooool !!!
I think once you have found the right values they will apply for anyone anytime :D
mrCarnivore
Post by mrCarnivore » Wed Mar 28, 2007 8:46 pm
Why don't you just use a mirrored ball? That's the same thing they use for hdr-probes...
Would be really easy in indigo as there is the sphere primitive: Just model a sphere and use Ag.nk as the material with a really high exponent. Then place it in the middle of the scene and render the sphere. If you want a latlong panorama you can always use hdrshop for conversion...
Wedge
Post by Wedge » Wed Mar 28, 2007 9:35 pm
Placing a mirrored ball in a scene is actually something I would like to try in my beach house. No matter what I do the scene has over five hundred objects in it and I can't find a good camera angle to get everything I want!! :)
Thanks for the tip mrCarnivore. I just might try this......some day.
rikokun
Post by rikokun » Wed Mar 28, 2007 9:45 pm
mrCarnivore> Thanks. I know about this plugin already but it doesn't solve my prob. You need to set the camera lens to 16 (90 degrees) in blender first and i don't know if that aply for camera in indigo as well...
As for mirror ball, that's no use either, cause now i need 6 pictures without panoramic deformation for our game engine. As for now, i'm learning radiosity in blender, cause i can achive nice results with it, but indigo is indigo ^_^
