[bug] strange rendered model
when i rendered the folloing model I recognizez a bug !!
but watch yourselves !
I turned the Normals to the right side.
The Material is Phong with some exponent and IRO to 1.5 .
- Modell.jpg (26.37 KiB) Viewed 3598 times
- RenderBug.jpg (96.78 KiB) Viewed 3598 times
I didn't have problems with normals, in blender, yet, except when there have been intersecting faces... they only would be used correctly, if normals would be pointing in both directions...
Can anyone explain me, why (choose one of these):
- BiDirectional Normals aren't possible
- BiDirectional Normals aren't a good idea
- or: noone thought about that
- At least it's not a good idea because if there was no normals (or BiDirectional normals as you call them) it would be much expansive for a raytracer to check wether a ray is currently inside or outside of a transparent, closed volume. Basically when a ray hits a transparent surface, if the normal is pointing outside the renderer knows it is entering a volume. Quick and easy, there is nothing to compute because the information is already embedded in the geometry.
The other way, if there exists no normal data, is to count the numbers of surfaces the ray traversed (?), wich in some cases (that is, very often) lead to errors. boooh. You want normals to be pointing in one direction only.
- So BiDirectional Normals are possible. Thats the very same that no normals data. Showing only one side of the surface is a technical choice.
- You, think about it again
I also have thought about it before and I like bidirections normals if there are also bi-material faces. That way you could easily model a fluid in a glass and the faces that are fluid on one side and glass on the other would simply get assigned two different materials (one at each side).
That would solve that problem with fluids and glass that they are either intersecting and lead to strange artefacts or have "air" between them which also leads to unwanted results...
However, thanks to the precedence system in indigo there is a neat way around this problem that works really nice.
Because "SetSmooth" essentially turns on normal smoothing (to both of the Blender exporters I know of).
Normal smoothing means that the normals of surrounding tris are averaged and interpolated across the face of the first tri - it prevents the common "blocky" looking 3d models by smoothing the lighting.
