SSS material tests
Post by Kram1032 » Wed Mar 21, 2007 3:03 am
You'd have to try this with the same model, to really tell this;) But I think, it's the same!
Post by OnoSendai » Wed Mar 21, 2007 3:11 am
You don't need to go thru blender: just use the .ply file directly.
Post by Kram1032 » Wed Mar 21, 2007 3:13 am
You've changed some things...
1) old:<rgb>0 0.45 0.5</rgb> new: <rgb>0 4.5 5</rgb> <- ten times of first absorbtion...
2) old: <rgb>0.1 0.5 5</rgb> new <rgb>4 20 200</rgb>
40 times SSS... the rest looks quite simmilar, but also the material looks fine, I'd say! You'd need to use the ToP Mod Mesh, for testring the differences...
mrCarnivore
Post by mrCarnivore » Wed Mar 21, 2007 3:26 am
OnoSendai wrote:You don't need to go thru blender: just use the .ply file directly.
And then it will work? :shock:
How can I position the object in the scene then?
I guess the problem with the colour really is finding the right combination and scale of the absorbtion and sss...
Still learning to handle sss. It's certainly not easy. :(
Post by Kram1032 » Wed Mar 21, 2007 3:51 am
The topmod modell is about 1m thick, at the thickest point and 20 cm at the thinnest... just try to scale the dragon to these things (first try thickest 1 m, then try the mesh to be just 20cm thick...
1 BU = 1 m)
homer_simpson
Post by homer_simpson » Wed Mar 21, 2007 10:03 pm
I am new to Indigo and first: it's a fine rendering program. The idea of progressive rendering is nice.
I play a little bit with an SSS material rendered with OpenEXR lightning.
The result had a rendering time of 8h 25m on a AMD 3700 with 2 GB RAM.
Homer
Stur
Post by Stur » Thu Mar 22, 2007 12:49 am
Welcome homer_simpson !
Nice picture with nice SSS. A little bit dark however, you should correct tonemapping with Violet if you saved an IGI file.
Post by Kram1032 » Thu Mar 22, 2007 12:52 am
welcome to Indigo, Homer^^
Nice SSS mat!
If you crank up the absorption, you could make tnit^^
mrCarnivore
Post by mrCarnivore » Thu Mar 22, 2007 1:19 am
Kram1032 wrote:If you crank up the absorption, you could make tnit^^
tnit?
Post by Kram1032 » Thu Mar 22, 2007 2:58 am
:oops:
tint, I meant, but this doesn't exist, xD
It's Ink, sorry
mrCarnivore
Post by mrCarnivore » Thu Mar 22, 2007 3:27 am
Indeed, it does look like blue ink. Just needs a little bit more absorbtion.
Another tip: Lighting this scene with an exr is just waste of time, I think. A meshlight would hve resulted in almost the same render...
manitwo
Post by manitwo » Thu Mar 22, 2007 3:32 am
mrCarnivore wrote:Another tip: Lighting this scene with an exr is just waste of time, I think.
as far as i remeber my tests, exr lighting isnt slower than meshlight lighting.
@homer: nice clean sss monkey you got there :wink:
mrCarnivore
Post by mrCarnivore » Thu Mar 22, 2007 3:42 am
manitwo wrote:as far as i remeber my tests, exr lighting isnt slower than meshlight lighting
It is not? Nice to know. Thx. Never made extensive tests, I just assumed... (Note to myself: stop assuming and try it out more often) :wink:
Post by Kram1032 » Thu Mar 22, 2007 3:44 am
But meshlights would be better to show the SSS effect.
Complex light looks more realistic, but it kills SSS :D
DaveC
Post by DaveC » Thu Mar 22, 2007 4:16 am
Kram1032 wrote::oops:
It's Ink, sorry
Oh! I thought you meant teenage ninja indigo tests.
