Clorophyl test, need help plz
Post by Kram1032 » Mon Mar 19, 2007 4:11 am
yes, I know... :D
Edit:
* :D * Can you post the .xml? How many pps? * :D *
* :D * = joke ;)
mrCarnivore
Post by mrCarnivore » Mon Mar 19, 2007 7:40 pm
First of all the material need a higher exponent. (what about 1000-3000)
The SSS-values should be much higher, too. (bias 50-150)
Also I would reduce the amout of red scatter. You can always increase it again afterwards.
Hope these tips help. :D
Post by Kram1032 » Tue Mar 20, 2007 3:13 am
reducing the amount of red scratter... hmmm.... And I thought, it's too blueish, xD, thanks anyway!
mrCarnivore
Post by mrCarnivore » Tue Mar 20, 2007 3:42 am
If it's too blueish you should reduce blue and not increase red.
Red is not the complementary color to blue! :D
Post by Kram1032 » Tue Mar 20, 2007 3:45 am
Yes, I know, cyan is the complimentary, but Í thought, red should be fine...
But I'll try anyway ;)
mrCarnivore
Post by mrCarnivore » Tue Mar 20, 2007 3:54 am
That's the same reasoning as when somebody adds sugar to compensate for a too salty meal. ;-)
The complementary colour to red is cyan and to blue is yellow... To compensate for a too blue sss eigther use less blue or more red AND green!
Post by Kram1032 » Tue Mar 20, 2007 4:00 am
Yes I know xD
Just stop with it, we both know it ;)
As I said, I'll try it, in ~20 min, I'll start with it! :D
mrCarnivore
Post by mrCarnivore » Tue Mar 20, 2007 4:08 am
What do you need 20 mins for? Need to buy some sugar for your salty meal? ;-)
Ok, I will stop now! Promise... :D
Can't wait to see your results. I'm an sss-newbie myself...
Post by Kram1032 » Tue Mar 20, 2007 5:16 am
I needed 20 minutes, 'cause my father told me to emty house-internal dustbins and load the externals 8) Then, I had to restart the system for some reason, but now, I'm rendering ;) (5min 55sek was last img.update ;))
Post by Kram1032 » Tue Mar 20, 2007 5:27 am
This is my new Material-try...
<medium>
		<name>Clorophyl.002</name>
		<precedence>20</precedence>
		<basic>
			<ior>1.5</ior>
				<rgb>
					<rgb>1 0 1</rgb>
				</rgb>
			<subsurface_scattering>
					<rgb>
						<rgb>5 7.5 0</rgb>
					</rgb>
				<phase_function>
					<uniform/>
				</phase_function>
			</subsurface_scattering>
		</basic>
	</medium>
	<material>
		<glossy_transparent>
			<exponent>500</exponent>
			<internal_medium_name>Clorophyl.002</internal_medium_name>
		</glossy_transparent>
	</material>
	<medium>
		<name>Clorophyl.001</name>
		<basic>
			<ior>1.5</ior>
				<rgb>
					<rgb>1 0 1</rgb>
				</rgb>
					<rgb>
						<rgb>0 11.25 7.5</rgb>
					</rgb>
				<phase_function>
					<uniform/>
				</phase_function>
		</basic>
	</medium>
	<material>
			<exponent>10000</exponent>
			<internal_medium_name>Clorophyl.001</internal_medium_name>
	</material>
	<material>
		<name>Clorophyl</name>
		<blend>
			<a_name>Clorophyl.001</a_name>
			<b_name>Clorophyl.002</b_name>
			<blend_factor>0.5</blend_factor>
		</blend>
	</material>
The new image will be added soon, after some more clear up ;)
Post by Kram1032 » Tue Mar 20, 2007 6:33 am
How is it?
After~1h 20 and~500 spp:
Newest Mat-test
Post by CTZn » Tue Mar 20, 2007 12:34 pm
Try lower exponent for the glossy, and use a lower ior (1.1 maybe). speculars are still too sharp IMO.
mrCarnivore
Post by mrCarnivore » Tue Mar 20, 2007 8:20 pm
Using a little less absorbtion and WAY more sss is the only thing I can think of now...
Post by Kram1032 » Wed Mar 21, 2007 2:55 am
mrCarnivore wrote:First of all the material need a higher exponent. (what about 1000-3000)
CTZn wrote: Try lower exponent for the glossy, and use a lower ior (1.1 maybe). speculars are still too sharp IMO.
lol?
Ok, I know, I used far too high exponent, this time...
A "way" more SSS -> more gain or more colour?
I didn't really find out, what gain does to the absorbtion... is it kinda a multiplier for the absorbtion values, or does it effect in a different way?
I'll lower the IOR and get the exponent to 500 and 1000... (so, one remains the same :P)
Just waiting for the look...
But I actually *think*, that the IOR is quite ok... should be IOR of 1.4 instead, as it's just like skin: water + dirt with a bit higher IOR... -> ~1.4
I'm pretty sure, that the IOR shouldn't be lower than water...
mrCarnivore
Post by mrCarnivore » Wed Mar 21, 2007 3:21 am
As far as I understand it, the gain is a multiplier for each colour value. So it is no difference which one you modify.
Sombody correct me if that's wrong pls.
So try to increase the sss so that the highest colour value of sss is about 200.
