SSS material tests
SSS material tests
Post by OnoSendai » Wed Jan 17, 2007 4:33 am
I plan to do some tests, messing round with parameters here.
Test scene is a modified one of radiances.
Will put up for download soon.
You will need to download the dragon from here:
http://www-graphics.stanford.edu/data/3Dscanrep/
The dragon is about 11cm tall in these renders.
You'll have to wait for 0.7 test 2 to use the henyey_greenstein phase function :)
EDIT: replaced with 2h45m render time version.
Material:
	<medium>
		<name>jade</name>
		<ior>1.6</ior>
		<precedence>20</precedence>
			<rgb>
				<rgb>2000 2 2000</rgb>
			</rgb>
		<subsurface_scattering>
				<uniform>
					<value>1000</value>
				</uniform>
			<phase_function>
				<henyey_greenstein>
					<g>0.8</g>
				</henyey_greenstein>
			</phase_function>
		</subsurface_scattering>
	</medium>
    <material>
		<name>default</name>
      <!--specular>
         <internal_medium_name>jade</internal_medium_name>
      </specular-->
		<glossy_transparent>
			<exponent>600</exponent>
		</glossy_transparent>
	</material>
Post by fused » Wed Jan 17, 2007 4:55 am
That looks absolutely beautiful! Awesome render.
nice dof btw :)
when can we expect test 2?
Post by OnoSendai » Wed Jan 17, 2007 4:56 am
test 2 will be out in the next few days i think.
Camox
Post by Camox » Wed Jan 17, 2007 6:02 am
Play with sss. The results are not really adequate. I have to find big difficulties the right values.
The yellow material is from Bandar ! Testscene from Ono and Bandar, thx guys for sharing. :wink:
sprocket
Post by sprocket » Wed Jan 17, 2007 6:13 am
Beautiful material!
Just curious, you say it is 11cm tall, is one unit in Indigo equal to one metre?
OnoSendai wrote:You'll have to wait for 0.7 test 2 to use the henyey_greenstein phase function Smile
:D Does thet mean there are other scattering functions like mie and rayleigh in the pieline too??
Post by OnoSendai » Wed Jan 17, 2007 6:28 am
Yes, Indigo units are metres.
I may get round to Rayleigh and Mie phase functions.
Would be pretty cool to actually simulate atmospheric scattering etc... with just a sunlight :)
Post by CTZn » Wed Jan 17, 2007 6:31 am
Camox wrote:thx guys for sharing. :wink:
Yes, thx people for sharing ! I'm silently copying every posted code in individual xml files for later use :D
Camox
Post by Camox » Wed Jan 17, 2007 6:45 am
Jo silently and auricularly ! What you use ? Your self contrived xml code ? :roll:
You are the best. :wink:
Kosmokrator
Post by Kosmokrator » Wed Jan 17, 2007 8:13 am
i think Ono u are genius...anyway i found an calculator for
Mie phase function i think may help u in some way
u have done amazing work in a sort time!!
http://www.lightscattering.de/MieCalc/
domparis
Post by domparis » Wed Jan 17, 2007 2:10 pm
Good result Nick, good to know a test2 is almost there :)
So i trying to get some decent result in a way to simulate skin, but like other already said, the specular effect is to much important at a ior between 1.3 and 1.5 and if i set it to a value near 1, i lost the real effect inside the volume.
Have u tracked the bug with skylight ?
Good work and thanks for your effort doing so many ehancement to your renderer !!
Dom
Ok, after seeing your code, using properly the glossy_transparent function help a lot ;)
Bandar
Post by Bandar » Thu Jan 25, 2007 10:42 pm
OnoSendai wrote:Would be pretty cool to actually simulate atmospheric scattering etc... with just a sunlight :)
Oooooh, yes :shock: :shock: :shock:
YaroslavL
Post by YaroslavL » Sun Feb 04, 2007 1:05 am
Can anybody share *.blend file with some SSS material?
Thanks.
________________
Yaroslav Lebidko
"3D XATA"
Photorealistic computer projection & design
of architecture constructions, interiors, furniture.
Ternopil, Ukraine
e-mail: ideja@3dxata.te.ua
web: www.3DXATA.com.ua
danyolgiax
Re: SSS material tests
Post by danyolgiax » Sat Mar 17, 2007 11:03 am
OnoSendai wrote: You will need to download the dragon from here:
What model i've to download?
Range data:
dragon_stand.tar.gz (6.1 MB compressed, 23 MB uncompressed)
dragon_side.tar.gz (4.2 MB compressed, 16 MB uncompressed)
dragon_up.tar.gz (5.7 MB compressed, 24 MB uncompressed)
dragon_fillers.tar.gz (6.7 MB compressed, 26 MB uncompressed)
dragon_backdrop.tar.gz (11 MB compressed, 44 MB uncompressed)
Vripped reconstruction:
dragon_recon.tar.gz (11 MB compressed, 43 MB uncompressed)
tnx
(Blender 2.46, Indigo 1.1.5, Blendigo 1.1.5)
Post by OnoSendai » Sat Mar 17, 2007 4:49 pm
You want
dragon_recon.tar.gz
mrCarnivore
Post by mrCarnivore » Tue Mar 20, 2007 10:58 am
I really have some problems with the dragon. I dl'ed the dragon and imported the .ply into blender. I tried res3 and res4 and with both I get some normals flipped and also non-manifold mesh. Re-calculating the normals made things even worse. I think it's because oof the non-manifold mesh that blender gets confused.
Can somebody pls post a blend with the dragon where those problems are not occuring?
Also I'm a little confused by the sss. I used blendigo to try to use this material:
http://www2.indigorenderer.com/joomla/f ... =8824#8824
My material code is this:
	<medium>
		<name>DragonMaterial</name>
		<precedence>10</precedence>
		<basic>
			<ior>1.2</ior>
				<rgb>
					<rgb>0 4.5 5</rgb>
				</rgb>
					<rgb>
						<rgb>4 20 200</rgb>
					</rgb>
				<phase_function>
					<uniform/>
				</phase_function>
		</basic>
	</medium>
	<material>
		<specular>
			<internal_medium_name>DragonMaterial</internal_medium_name>
		</specular>
	</material>
Seems almost the same to me, doesn't it? The result, however, looks nothing like the original post:
What am I doing wrong?
Users browsing this forum: No registered users and 146 guests
