Indigo for Cinema 4D 4.4.10 Beta
15 posts • Page 1 of 1
Post by fused » Fri Jul 31, 2020 5:53 am
Mostly adding new Indigo features and bugfixes.
R20 version supported: R20.059
R21 version supported: R21.207
Note: R21 builds should also work for S22.118.
Windows:
Indigo Renderer:
indigo-for-cinema-4d-4.4.10-installer.exe - Includes installers for R12 - R19
indigo-for-cinema-4d-R20-4.4.10-installer.exe - Includes installers for R20 - R21
Indigo RT:
indigo-rt-for-cinema-4d-4.4.10-installer.exe - Includes installers for R12 - R19
indigo-rt-for-cinema-4d-R20-4.4.10-installer.exe - Includes installers for R20 - R21
Mac:
Indigo Renderer
indigo-for-c4d-4.4.10-R12-mac.zip
indigo-for-c4d-4.4.10-R13-mac.zip
indigo-for-c4d-4.4.10-R14-mac.zip
indigo-for-c4d-4.4.10-R15-mac.zip
indigo-for-c4d-4.4.10-R16-mac.zip
indigo-for-c4d-4.4.10-R17-mac.zip
indigo-for-c4d-4.4.10-R18-mac.zip
indigo-for-c4d-4.4.10-R19-mac.zip
indigo-for-c4d-4.4.10-R20-mac.zip
indigo-for-c4d-4.4.10-R21-mac.zip
Indigo RT
indigo-rt-for-c4d-4.4.10-R12-mac.zip
indigo-rt-for-c4d-4.4.10-R13-mac.zip
indigo-rt-for-c4d-4.4.10-R14-mac.zip
indigo-rt-for-c4d-4.4.10-R15-mac.zip
indigo-rt-for-c4d-4.4.10-R16-mac.zip
indigo-rt-for-c4d-4.4.10-R17-mac.zip
indigo-rt-for-c4d-4.4.10-R18-mac.zip
indigo-rt-for-c4d-4.4.10-R19-mac.zip
indigo-rt-for-c4d-4.4.10-R20-mac.zip
indigo-rt-for-c4d-4.4.10-R21-mac.zip
Changelog:
* Added Fabric material type.
* Added fabric material preview scene.
* Added main beauty layer.
* Fixed crash on export by missing phong tag on perfect sphere.
* Drawing of region render frame (well, kind of).
* Some other minor fixes and changes.
* Updated Indigo sdk version to 4.4.10.
wob
Re: Indigo for Cinema 4D 4.4.10 Beta
Post by wob » Fri Jul 31, 2020 6:28 am
cool! will test)
wob
Post by wob » Fri Jul 31, 2020 7:22 am
ideal sphere renders only in cpu mode... why?
Post by fused » Fri Jul 31, 2020 8:21 pm
Added a small fix for mlt in ipr.
wob wrote: ↑
Indigo's gpu renderer does not support perfect spheres. It should really replace them with sphere meshes, but it doesn't.
Maybe at some point there was code that exported a poly sphere in cindigo to handle this, but I guess it broke along the way.
I'll look into it.
wob
Post by wob » Fri Jul 31, 2020 9:51 pm
fused wrote: ↑
wob wrote: ↑
I'll look into it.
very important to implement scatter object in cindigo. very usable feature to completely finish off octane and redshift ;)
p.s. old epical problem with section plane is still here)
pavoda
Post by pavoda » Fri Jul 31, 2020 11:14 pm
Not working for me (R21.1)...plugin Indigo not appier in C4D
Post by fused » Fri Jul 31, 2020 11:37 pm
pavoda wrote: ↑
It's compiled against the latest C4D R21, which is 21.207.
Unfortunately, since R20, plugins are binary incompatible even on minor patches, so you'll have to update your C4D.
I'd list the versions they are compiled against, but there isn't even a way to (programmatically) tell the version of a c4d sdk or exe... But maybe I should keep track of it manually...
edit: I realise how complicated it makes having all your plugins working in one install of C4D. But I think Maxon didn't realise this when they made this change. :)
Zalevskiy
Post by Zalevskiy » Fri Jul 31, 2020 11:51 pm
Please tell me, triplanar mapping does not work because of the indigo c4d exporter or the engine itself does not support this function?
Triplanar.zip
(12.17 MiB) Downloaded 918 times
Zalevskiy
Post by Zalevskiy » Fri Jul 31, 2020 11:54 pm
del
Post by lycium » Sat Aug 01, 2020 12:02 am
Hi, I was randomly testing in R22 and have some smol bug reports :)
1. IPR doesn't seem to work in GPU mode: to reflect scene changes you have to click stop and then start again.
2. CPU IPR sometimes gets stuck in low res without updating to 1:1 pixels (see attachment).
Post by fused » Sat Aug 01, 2020 12:20 am
lycium wrote: ↑
Interesting, that's a new one, it seems. Probably some change in Indigo I'm not aware of.
lycium wrote: ↑
Yes, I am aware of that one. No luck in catching that one yet.
Thanks.
edit: wait, actually I'm not sure if indigo allows changes to the models in GPU mode yet. I don't think it does at the moment.
only camera and material changes.
wob
Post by wob » Sat Aug 01, 2020 2:02 am
fused wrote: ↑
lycium wrote: ↑
very old and well known in pro-chats indigo's ipr problem ;)
p.s. also... cindigo 4.4.10 has no updated changelog.txt ;)
Post by fused » Sat Aug 01, 2020 3:18 am
wob wrote: ↑
I did replace the build you downloaded with one more small fix later, and it also has the updated changelog.
mpro31
Post by mpro31 » Sat Aug 01, 2020 6:36 am
c4d 19.053 / mac here
-no preview in materials
-infinite color wheel in IPR
Post by fused » Sun Aug 02, 2020 6:14 am
mpro31 wrote: ↑
Hm, I do compile R19 against a rather old verion, R19.024. I will try to update it to 19.053. Can I pm you a build?
Btw, does the console say anything of interest? Under Scripts > Console.
Also, what version of MacOS?
