h
Re: h
8.25 millions of instances.
Works well, thank you Ono! Hello wob.
Here is an old example pigs by Ono that contains the scatter function.
Actually there is no possibbility of use inside Cinema. ATM only Skindigo has implemented the scatter function.
You must setup the scatters in XML. Noticed that the meshes to be scattered requires the "mesh UID" and the target object requires the "object UID". If Cindigo must write 8.25 millions of instances in the igs... you need hours of exportation. Indigo´s scatter put the instances directly in scene...
Hope that it will be implemented inside Cindigo someday.
Re: h
"You must setup the scatters in XML"yonosoy wrote: ↑Tue Jun 23, 2020 1:55 am8.25 millions of instances.
Hello Wob.
Here is an old example pigs that contains the satter function.
scatter_material_test.pigs
is this available for cinema 4d? can i use scatter with that xmls with cinema?
it's really great function, with full realisation in standalone app, why is it not added to cindigo gui yet? i tested your scene, it works fine
Re: h
Open the exported quickrender.igs in notepad. This is, XML (the text language of Indigo and many other programs).
So, the procedure:
1- Export the scene (with the objects to be scattered and the target object, as is).
2- Open the igs in a text editor.
3- Add this code at the end:
4- Change the geometry_uid and the material_uid to fit your object to be scattered (you can repeat a chain of code to scatter multiple objects).
geometry_uid > uid of the mesh in the file.
material_uid > uid of the material of the object.
5- Change the target_object_uid, use the uid of the model2 in the file.
6- setup parameters.
If you want to scatter more than one object looks like this:
If your object has more than one material:
Hope this help.
So, the procedure:
<scatter>
<uid>800000</uid>
<name>the scatter</name>
<shader>
<shader><![CDATA[
def evalScale(int index) real :
1.0
def evalCreate(int index, vec3 p) bool :
true
]]></shader>
</shader>
<proto_object_groups>
<proto_object_group>
<geometry_uid>8</geometry_uid>
<materials>
<material_uid>7</material_uid>
</materials>
<weight>1</weight>
</proto_object_group>
</proto_object_groups>
<density>2</density>
<seed>1</seed>
<view_culling>true</view_culling>
<orient_normal>false</orient_normal>
<scale_std_dev>0.35</scale_std_dev>
<height_std_dev>0.2</height_std_dev>
<evenness>0.02</evenness>
<z_offset>0</z_offset>
<target_object_uid>25</target_object_uid>
</scatter>geometry_uid > uid of the mesh in the file.
<materials>
</materials>
<weight>1</weight>
<geometry_uid>12</geometry_uid>
<materials>
<material_uid>11</material_uid>
</materials>
<weight>1</weight>
</proto_object_groups>Code: Select all
<materials>
<material_uid>16</material_uid>
</materials>
<weight>1</weight>
Re: h
thank you, i'll try, but it will not work with animation (multiple igs files) as i see, just if i'll make automation for including this text into every igs file in queue... perpahs, can i include this code into cinema 4d scene as indigo isl shader code or as any type of python script?yonosoy wrote: ↑Tue Jun 23, 2020 4:29 amOpen the exported quickrender.igs in notepad. This is, XML (the text language of Indigo and many other programs).
So, the procedure:
3- Add this code at the end:4- Change the geometry_uid and the material_uid to fit your object to be scattered (you can repeat a chain of code to scatter multiple objects).Code: Select all
<scatter> <uid>800000</uid> <name>the scatter</name> <shader> <shader><![CDATA[ def evalScale(int index) real : 1.0 def evalCreate(int index, vec3 p) bool : true ]]></shader> </shader> <proto_object_groups> <proto_object_group> <geometry_uid>8</geometry_uid> <materials> <material_uid>7</material_uid> </materials> <weight>1</weight> </proto_object_group> </proto_object_groups> <density>2</density> <seed>1</seed> <view_culling>true</view_culling> <orient_normal>false</orient_normal> <scale_std_dev>0.35</scale_std_dev> <height_std_dev>0.2</height_std_dev> <evenness>0.02</evenness> <z_offset>0</z_offset> <target_object_uid>25</target_object_uid> </scatter>
If you want to scatter more than one object looks like this:If your object has more than one material:Code: Select all
<proto_object_groups> <proto_object_group> <geometry_uid>8</geometry_uid> <materials> <material_uid>7</material_uid> </materials> <weight>1</weight> <geometry_uid>12</geometry_uid> <materials> <material_uid>11</material_uid> </materials> <weight>1</weight> </proto_object_group> </proto_object_groups>Hope this help.Code: Select all
<proto_object_group> <geometry_uid>8</geometry_uid> <materials> <material_uid>7</material_uid> <material_uid>16</material_uid> </materials> <weight>1</weight> </proto_object_group>![]()
Re: h
The right procedure is to use several protogroups, one per object to be scattered (instructions corrected).
20 million. Scale of grass X2. .
Corrections in 16 bit, without LUTs. .
wob, wait for the update in the exporters for animations, it has been announced.
Ono, a bug with subdivision and scatters; more than 3 subdivisions produces this...
- Originalplan®
Re: h
Superb work Yonosoy!
Re: h
Technical stuff of v2...
v2.08...
Two hours. Accepts in blender a coating thickness of 1.375e-06 (only the first and the last lenses coated in this moments). Near to a perfect focus plane. Still working...
It is strictly functional (see blender capture).
v2.08...
Users browsing this forum: No registered users and 84 guests
