portal problem with Indigo GPU
Come here for help & support.
9 posts • Page 1 of 1
gzavye
Post by gzavye » Tue Apr 17, 2012 3:47 am
I'm testing Indigo with interior scene Classroom.
I would to render with GPU using portals on windows.
But I have a litle problem because sun disapear in the room.
It's working when I'm computing with CPU...
Is there imcompatibility btwn GPU and portals?
Scene without portals. Sun appears.
Scene with portals. No sun and fireflies
Re: portal problem with Indigo GPU
Post by OnoSendai » Tue Apr 17, 2012 3:54 am
The problem is that GPU forces render mode to single-directional path tracing, which doesn't work well with exit portals. Exit portals only work well with bidirectional path tracing.
gzavye
Post by gzavye » Tue Apr 17, 2012 9:33 pm
Thanks for your answer.
So do you have an advice to improve interior render in interior scenes?
if the solution is not in software, is it possible to render on network with GPU on each slave?
And to finish, do you plan to add multi GPU and/or improve pathtracing in GPU mode?
Post by CTZn » Wed Apr 18, 2012 9:41 am
Hi Gzavye,
Probably the most robust method, as it always is, would be bidir with MLT. Exit portals can be used with MLT also, as Ono said the "sun not showing through portal" issue is intrinsic to single path tracing based methods (rays are shot from the camera only and odds to hit the tiny sun are therefore pretty sparse among all possible bouncing combos).
My workflow for evaluation would be:
1: remove EPs and test GPU.
2: add EPs and test bidirectional PT
3: add MLT on top
Most often I would use bidir+MLT but that's just me, I even used that mode for the wheat field renders (exteriors, see this post and above. hmm now I see it's undersampled after 15mn).
I don't own a network (have single node) but anyways network rendering will not make PT behave better with sun and EPs. Yes, slaves will use GPU if the hardware requirements are met.
Multi GPU is certainly planned because lycium, who worked a lot on the current PT implementation, mentioned that it would happen at some point.
Despite its limitation with sun trough EP (wether it can be adressed I don't know) Indigo's PT is far from brute force, "smart" rather. It's logical enhancement is bidir (PT, but also shot from light sources with importance sampling).
cheers
Post by OnoSendai » Wed Apr 18, 2012 10:12 am
gzavye wrote:Thanks for your answer.
Hi gzavye,
We do indeed plan to both add multi-GPU support, and to support bidirectional path tracing with GPU acceleration.
Alain
Post by Alain » Thu May 10, 2012 3:13 am
Hi gzavye,
Is this this implemented meanwhile ?
Kind regards
Alain
Win 7 64 Bit, 8 GB RAM, Geforce GTX 480, Blender 2.62, Indigo RT Trial, Blendigo 3.2.12.0
easyarchitect
Post by easyarchitect » Sun May 10, 2020 3:53 pm
It's now eight years since this statement, as many people like me are using Indigo do interiors, I wonder if we will ever do bidirectional path tracing + GPU in Indigo.
Is there any hope of that, or has this hypothesis been abandoned?
Thank you
AD
Post by OnoSendai » Sun May 10, 2020 6:33 pm
Hmm maybe, but some kind of exit portal improvements for single-dir might be a better approach for GPU initially.
easyarchitect
Post by easyarchitect » Sun May 10, 2020 6:56 pm
Thank you for your answer, Indigo is an excellent product that I have been following for years because of its physical precision of materials.
However, the speed of calculation is also important for those who cannot afford over a thousand Euro video cards to be used with a "brute force" approach.
Some clever optimization in the direction of exit portals is wellcome !
AD
