[SOLVED] Shader function "sample2DTextureVec3" not working anymore...
4 posts • Page 1 of 1
easyarchitect
Post by easyarchitect » Sun Mar 29, 2020 7:46 pm
Hi, I'm trying to export an Indigo scene from my CAD application.
The shader below does't work anymore (it worked with an older Indigo version)
This is the shader.
I've done some test, the shader works, is the function "sample2DTextureVec3" that seems to always return (0,0,0)
Please help !!
Thank you
Antonio
<material> <!-- IgsMaterialType : "IgsDiffuse" -->
  <name>Material_12</name>
  <diffuse>
    <texture>
      <!-- TextureMap[0] : "Immagine primaria" -->
      <uv_set>default</uv_set>
      <path>.\MAINA SALA (baco)\MATTONI%20PIETRA%20ECRU_BUMP_IMG1.bmp</path>
      <exponent>2.2</exponent>
      <b>1</b>
      <c>0</c>
    </texture>
    <texture>
      <!-- TextureMap[1] : "Mappa livello bumping" -->
      <uv_set>uv_set1</uv_set>
      <path>.\MAINA SALA (baco)\MATTONI%20PIETRA%20ECRU_BUMP_BUMP.bmp</path>
      <b>0.001000</b>
      <c>0</c>
    </texture>
    <albedo>
      <shader>
        <shader>
          <![CDATA[
            def multiplyColor(vec3 col1, vec3 col2) vec3: vec3(mul(doti(col1),doti(col2)),mul(dotj(col1),dotj(col2)),mul(dotk(col1),dotk(col2)))
            def eval(vec3 pos) vec3 : multiplyColor(sample2DTextureVec3(0,getTexCoords(0)),vec3(0.992157,0.960784,0.901961))
        </shader>
      </shader>
    </albedo>
    <bump>
      <texture>
        <texture_index>1</texture_index>
      </texture>
    </bump>
  </diffuse>
</material>
easyarchitect
Re: Shader function "sample2DTextureVec3" not working anymore...
Post by easyarchitect » Sun Mar 29, 2020 8:03 pm
To help you, I've created a sample Image.
The vase has this Material below:
<material>
  <name>Material_14</name>
  <diffuse>
    <texture>
      <path>CAST_IMG1_V2.bmp</path>
      <b>1</b>
      <c>0</c>
    </texture>
    <albedo>
      <shader>
        <shader>
          <![CDATA[
            def eval(vec3 pos) vec3 : sample2DTextureVec3(0,getTexCoords(0))
        </shader>
      </shader>
    </albedo>
  </diffuse>
</material>
Everything else has this material below:
<material>
    <name>Material_17</name>
    <diffuse>
      <texture>
        <b>1</b>
        <c>0</c>
      </texture>
      <albedo>
        <texture>
        </texture>
      </albedo>
    </diffuse>
  </material>
This is the result
Post by Zom-B » Sun Mar 29, 2020 9:36 pm
Can you tell the Indigo version where this shader worked?
I added this issue to the bugtracker, so thank you for reporting!
easyarchitect
Post by easyarchitect » Sun Mar 29, 2020 9:59 pm
[SOLVED]
Starting from Indigo 3.6.14, the texture used by shader must be declared locally to the shader...
Here is the correct shader:
<material>
  <diffuse>
    <texture>
      <b>1</b>
      <c>0</c>
    </texture>
    <albedo>
      <shader>
    	<texture>
    	</texture>
        <shader>
          <![CDATA[
        </shader>
      </shader>
    </albedo>
  </diffuse>
</material>
bye
R
