Even with the simplest scene:
whenever I switch the viewport to show the view of an indigo IM_Camera -> 3ds max crashes.
I can not see any workaround rather than using another type of camera, but I intent to use the depth of field.
Can that be fixed?
Cheers Christoph
3Ds Max 2017, indigo max 0.5.0 crash with im camera
Re: 3Ds Max 2017, indigo max 0.5.0 crash with im camera
Hi there, same problem with 3dsmax 2019 and indigo max 0.7.4,
an idea for this problem ? Thanks
Stfano
Stfano
Hi Stfano,
I can't replicate this behaviour with 3dsmax 2019. Does it happen in a clean project? If not, can you send a project file? What other plugins do you have installed?
Best,
Yves
Hi Yves,
I'm actually using a student version of 3dsmax 2019 and trial version of Indigo.
Plugins installed with clean licences are Forest Pack and Railclone.
You can see on screenshots that it's a simple IM Camera with a selected box in the scene.
On perspective view it's ok and when i'm switching on camera view an error message appear.
Thanks for your help,
Best regards,
Stfano
Best regards,
Stfano
