Indigo Renderer 4.4.1 Beta / Technology Preview
Re: Indigo Renderer 4.4.1 Beta / Technology Preview
Post by Zom-B » Tue Sep 03, 2019 11:05 pm
Hey Sroka8888,
just as Ono explained the denoiser is only working with GPU rendering atm, and you are right: its because of the sampling method CPU rendering uses.
Saving EXR does work fine, but does take quite some time since on saving the denoiser restarts. If you also save Render Channels it does take some extra time since passes like direct and indirect lighting etc. is processed separately...
Doublecheck your log file while saving.
Originalplan®
Post by Originalplan® » Wed Sep 04, 2019 12:46 pm
This is a pretty f*ckin dope realease to put it blunt.
Tho leave feedback here on the *optimeze for denoise* and *denoise button* find it a bit overcomplicated.
sger
Post by sger » Sun Sep 08, 2019 2:32 am
Post by pixie » Sun Sep 08, 2019 2:42 am
optimize denoise just add two render passes "albedo" and "normal" used by the denoise algorithm
Lal-O
Post by Lal-O » Mon Sep 09, 2019 6:03 am
Hi ! Thx for this new update ! I am gonna give it a try right away :) .... and I'm glad for you to using the scene i've created for the contest to show it as example of what indigo's denosing can achieve :).
My best regards.
sger
Post by sger » Tue Sep 10, 2019 12:55 am
Great it works!
how to mesure gpu?
Post by Zom-B » Tue Sep 10, 2019 4:08 am
Zalevskiy
Post by Zalevskiy » Fri Sep 27, 2019 1:01 am
del
Zalevskiy
Post by Zalevskiy » Fri Sep 27, 2019 1:26 am
del
background_luminance_test.pigs
(2.54 KiB) Downloaded 648 times
isl.pigs
(2.5 KiB) Downloaded 657 times
pavoda
Post by pavoda » Wed Oct 09, 2019 12:01 am
I have some comments to this version:
- Denoising does not seem to work with aperture diffraction
- When rendering a video with denoising function, after only a few (10-20) frames, indigo starts to generate only black frames. After restart indigo it is ok, but only for next few frames.
- Desnoising for large resolutions takes a long time in this time gpu not working. I would recommend manually adjusting the denosing interval, or just before the rendering process ends
- When I render a video, Indigo builds scene for every frame. In many cases, only the camera could move around a static scene. It would save a lot of time.
- It would be appropriate to allow the adjustment of the denosing intensity.
Thanks for the good work!
Zalevskiy
Post by Zalevskiy » Tue Oct 15, 2019 6:44 pm
del
loniek
Post by loniek » Sat Oct 19, 2019 9:24 am
I`m getting strange results using Indigo RT for sketchup (trial for now). Without denoising everything works great.
Zalevskiy
Post by Zalevskiy » Tue Nov 12, 2019 9:56 pm
1. octane render ~ 1 hour render
2-3-4. indigo + denoise + gpu ~ 10-15 min amazing!
I note that in indigo the aperture + gpu + denoise does not work correctly
bloom in the octane, although artificial, but reacts in real time, I would like the same quick adjustment of the flare
Post by pixie » Mon Dec 09, 2019 1:51 am
Great work Zalevskiy!
sger
Post by sger » Wed Apr 08, 2020 4:29 am
is it looks as real scene?
Users browsing this forum: No registered users and 97 guests
