gpu - black widow - bad drivers
Come here for help & support.
10 posts • Page 1 of 1
sger
Post by sger » Fri Sep 06, 2019 3:08 am
Building OpenCL scene data.
Num buffer layers: 1
Master buffer size: 42.923 MB
Settings:
Image width: 1280 px
Image height: 720 px
Supersample factor: 2
Internal image width: 2576 px
Internal image height: 1456 px
Verbose: false
Image save period: 3600 s
Splat filter: FastBox
Downsize filter: mn_cubic, blur=1.000, ring=-0.000, support=3.200px
Metropolis: false
Bidirectional: false
Aperture diffraction: false
Post-process diffraction: true
Auto setting number of threads to 8.
Finished initialisation (Time Taken: 0.16 s)
AutoFocus: setting camera focus distance to 0.099 m.
OpenCL code for 'specular' on Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz built. (from cache, elapsed: 0.04769 s)
OpenCL code for 'phong' on Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz built. (from cache, elapsed: 0.04760 s)
OpenCL code built: (elapsed: 0.04848 s)
OpenCL code for 'specular' on Radeon RX 560 Series, Radeon RX 560 Series built. (from cache, elapsed: 0.07489 s)
OpenCL code for 'phong' on Radeon RX 560 Series, Radeon RX 560 Series built. (from cache, elapsed: 0.07295 s)
OpenCL code built: (elapsed: 0.07584 s)
Starting threads... (num threads: 8)
Starting render thread. (RNG seed=0)
Optimised OpenCL code for 'specular' on Radeon RX 560 Series, Radeon RX 560 Series built. (from cache, elapsed: 0.005879 s)
Optimised OpenCL code for 'phong' on Radeon RX 560 Series, Radeon RX 560 Series built. (from cache, elapsed: 0.01002 s)
Optimised OpenCL code for 'specular' on Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz built. (from cache, elapsed: 0.02729 s)
Optimised OpenCL code for 'phong' on Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz built. (from cache, elapsed: 0.02645 s)
Re: gpu - black widow - bad drivers
Post by Zom-B » Fri Sep 06, 2019 3:53 am
Disable the CPU
sger
Post by sger » Fri Sep 06, 2019 9:04 pm
all the same, but bench is working
Post by fused » Fri Sep 06, 2019 10:49 pm
Does the scene render fine with CPU PT?
sger
Post by sger » Sat Sep 07, 2019 2:23 am
yes v-well
sger
Post by sger » Sat Sep 07, 2019 11:40 pm
Logs looks correctly..
May be 4.064 ver. will works? (like bench)?
Is there any way start render with indigo_console from *.pigs?
indigo_gpu_info.txt
(6.43 KiB) Downloaded 662 times
Post by Zom-B » Sun Sep 08, 2019 1:05 am
what Indigo version do you use?
Try the latest: 4.4.1
viewtopic.php?f=1&t=15253
sger
Post by sger » Sun Sep 08, 2019 2:31 am
sger
Post by sger » Tue Sep 10, 2019 12:49 am
Great it works!
tarjetasgraficas
Post by tarjetasgraficas » Mon Sep 16, 2019 8:10 pm
I had the same problem, 4.4.1 fix it.
Thank u very much!
Users browsing this forum: No registered users and 119 guests
