0.6 test 2... half baked or fully baked? :)
Should i release 0.6 test 2 now?
yes
32
78%
no
9
22%
Total votes: 41
Post by OnoSendai » Sun Sep 03, 2006 12:37 am
Ok... so i've got a really half-baked release, 0.6 test2,
that i could put up. Since i recoded so much stuff, a *lot* of stuff is broken.
Broken things:
normal (backwards) path tracing, dispersion, absorption, image saving in non-mlt mode, double sided mats, probably lots of other stuff too.
However, what's there works really well, and should be faster and with less noise?
So do people want to try this out, or should i fix it all first? (may take a week or so)
arneoog
Post by arneoog » Sun Sep 03, 2006 12:48 am
I don't know :)
But if you put it up now we will still get the fixed version when it's done.. ...right? 8)
So It's the same for me :P :? heh...
Edit: Maybe you should, at least if there is some new stuff we exporter writers need to add in :)
Post by OnoSendai » Sun Sep 03, 2006 12:50 am
Yes... i will still fix the missing features :)
EDIT: the scene format is unchanged, it's just the rendering core that has changed.
Jedrzej_s
Post by Jedrzej_s » Sun Sep 03, 2006 12:59 am
I want this broken test release :). I want test it :). Would be nice to see now what you did Ono with Indigo :).
Regards and THX :)
Behrendt
Post by Behrendt » Sun Sep 03, 2006 1:06 am
NO! Please don't release any 0.62 or something. In the past versions many small things didn't work, for every release a new exporter and so on. I think it gets impossible to get an good workflow with many of this bugs.
Post by OnoSendai » Sun Sep 03, 2006 1:08 am
Behrendt: well, you don't *have* to use it
Jedrzej_s
Post by Jedrzej_s » Sun Sep 03, 2006 1:10 am
Behrendt <- YES, he don't *have* to use it :)
But I want use it !!! Ono, give us this test version, please !!!!!!! :)
Post by Zom-B » Sun Sep 03, 2006 1:18 am
I would love to get a v062 for testing!!!
But I think its realy important to post a "Knowen Bugs List" too, not only a changelog!
So everybody would know what the v062 is all about, reducing bug posting of stuff that is already known!
Post by OnoSendai » Sun Sep 03, 2006 1:23 am
5 vs 3: release it is :)
EDIT: taken down, it crashes outside of the IDE :)
EDIT EDIT: time for some coffee, then i will fix and re-release!!!:)
list of broken stuff coming...
General guide: just stick to bidir path tracing or bidir with MLT.
And remember that only bidir with MLT saves the image to disk :)
zuegs
Post by zuegs » Sun Sep 03, 2006 1:29 am
I think it's your descition. If you like to get some feedback from us about the new version then you should release it. If you don't like to answer a list of questions about what why does not ....... then do not :wink:
By the way I just saw you released it... :shock: :D ok, there we will go... 8)
EDIT: and away :( :cry: I was too slow :wink:
EDIT EDIT: take your time, will take a coffee too for you :lol:
Jedrzej_s
Post by Jedrzej_s » Sun Sep 03, 2006 1:34 am
Hmmmm... we will wait :).
manitwo
Post by manitwo » Sun Sep 03, 2006 1:41 am
wohooo :lol: can't wait to test it
zuegs
Post by zuegs » Sun Sep 03, 2006 1:45 am
www.indigorenderer.com should have a chat-page/waiting-room for such moments :) :wink:
Post by OnoSendai » Sun Sep 03, 2006 1:55 am
Ok.. another attempt at working-ness:
http://www.indigorenderer.com/montecarl ... _test2.zip
EDIT:
changelog:
v0.6 test 2
* changed some stuff so that bump mapping won't hang warmup on dodgy geometry.
* fixed bump mapping for phong that was broken for v0.6 test 1
* Added PNG texture loading
* rewrote bidir stuff
* speedup for objecttree
* improved/fixed bidir and sky interaction
* kd-tree cache on disk (think this is new in 0.6 test2???)
* speedups for spectral BSDF and exitant radiance calculations
-----------broken stuff:-----------
double sided mats (probably)
possible all bump mapping / shading normals
dispersion
absorption
backwards path tracing
image saving for non-mlt bidir
etc...
zuegs
Post by zuegs » Sun Sep 03, 2006 2:10 am
i get this:
"MLTPathTracer::buildPathFromSamples disabled." ??? :?:
EDIT: Sorry, i think forgot to enable bidir ....
EDIT: It works :D speculars on phong are phantastic/fast, much less of noise :D rounded surfaces are brocken/flat :oops:
