Phoenix
by Phoenix » Wed Mar 14, 2007 12:24 pm
There are a few things I noticed:
When I export from C4D my scene always is named "justsomerandomcrap.xml" whether if I add the extension ".xml" to my chosen name or not. But the .3ds and .obj files get the right names.
The menue point "Info..." in the Indigo Exporter plugins folder in C4D shows nothing.
I tried both of these with the C4D releases R9.6 and R10.
And, by the way, why does the main plugin file still has the name of the cinema4dsdk and is not changed to something own like "IndigoExporter.cdl" or something similar?
But non the less, thank you very much for all your work!
okazaky
by okazaky » Thu Mar 15, 2007 10:08 pm
Thank you so much for your hard work!
(I didn't know that you have been a 3D-Ring member, cool
jackei
by jackei » Thu Mar 15, 2007 11:59 pm
hy...i have a problem:
with cinema 4d releas 10 the exporter doesn't work. cinema 4d crashes and the indigo render is white...what is the problem?
greez..jackei
manitwo
by manitwo » Fri Mar 16, 2007 12:29 am
i have the same problem with r10 - c4d crashes when i try to export -
example scene works tho - really confusing.
btw: hello jackei!
jackei
by jackei » Fri Mar 16, 2007 5:10 am
hy manitwo...yes i know. it's a long time since i wrote something in this forum=)
kadajawi
by kadajawi » Fri Mar 16, 2007 2:20 pm
Probably you've messed something up in the indigo render tags or the objects you applied them too. In my case I had something as plane instead of a polygon object.
@fused: Great work so far, and I like the idea with the default material. At least something
Hris
by Hris » Sun Mar 18, 2007 9:11 am
I want to sorry you guys, because i promised last week, that i'll try to write some tutorial for this exporter...but i was hardworking in my job and i had no time for this...
well, Mr.Fused i'm still surprised that you still can find time for work with exporter. Take my respect for you.
Greets from Poland
Hris
jackei
by jackei » Mon Mar 19, 2007 12:21 am
does anybody work with cinema 4d r.10? i have still the same problem. maybe someone could upload a c4d r.9 file and the exportet files that works with this exporter....then i can see whats the problem.
greez jackei
jackei
by jackei » Mon Mar 19, 2007 12:26 am
greez jackei
edit: now i think i know what's the problem. the exporter doesn't export the <mesh> tags in the xml. only for my meshlight. when i use a indigo-objekt tag the exporter crashes:(
<?xml version="1.0" encoding="UTF-16" ?>
<!--generated by Indigo Exporter for C4D-->
<!--using TinyXml-->
<scene>
<renderer_settings>
<width>800</width>
<height>600</height>
<metropolis>true</metropolis>
<bidirectional>false</bidirectional>
<max_num_consec_rejections>100</max_num_consec_rejections>
<max_depth>1000</max_depth>
<halt_time>-1</halt_time>
<save_igi>true</save_igi>
</renderer_settings>
<camera>
<pos>-5.41212 -0.91150 5.16513</pos>
<up>0.67582 0.11382 0.72822</up>
<forwards>0.71811 0.12094 -0.68534</forwards>
<aperture_radius>0.02</aperture_radius>
<focus_distance>0.36</focus_distance>
<sensor_width>0.036</sensor_width>
<lens_sensor_dist>0.036</lens_sensor_dist>
<aspect_ratio>1.333</aspect_ratio>
<white_balance>D65</white_balance>
<autofocus />
</camera>
<background>
<spectrum>
<rgb>
<rgb>0 0 0</rgb>
</rgb>
</spectrum>
</background>
<tonemapping>
<reinhard>
<pre_scale>1</pre_scale>
<post_scale>1</post_scale>
<burn>6.0</burn>
</reinhard>
</tonemapping>
<mesh>
<!--Platonischer Körper-->
<name>justsomerandomcrap0</name>
<normal_smoothing>false</normal_smoothing>
<external>
<path>justsomerandomcrap0.3ds</path>
</external>
</mesh>
<material>
<name>kugel</name>
<phong>
<ior>1</ior>
<diffuse>0.85 0.85 0.85</diffuse>
<exponent>1000</exponent>
</phong>
</material>
<material>
<name>boden</name>
<diffuse>
<colour>0.85 0.85 0.85</colour>
</diffuse>
</material>
<meshlight>
<scale>0.01</scale>
<pos>-0.324 -2.889 4.354</pos>
<rotation>
<matrix>1 0 0 0 1 0 0 0 1</matrix>
</rotation>
<mesh_name>justsomerandomcrap0</mesh_name>
<spectrum>
<blackbody>
<temperature>6500</temperature>
<gain>1</gain>
</blackbody>
</spectrum>
</meshlight>
</scene>
manitwo
by manitwo » Mon Mar 19, 2007 12:49 am
right - same over here. (r10)
you succeed in isolating the problem
WLAD
by WLAD » Mon Mar 19, 2007 1:00 am
hi jackei,
get you always this wrrong xml export?
for me the exporter works well.
WLAD
jackei
by jackei » Mon Mar 19, 2007 8:07 am
yes always. the exporter doesn't work well with c4d r10.
by fused » Mon Mar 19, 2007 8:21 am
there will be an update soon. it will have proper error handling
sry i was pretty lazy.
and maybe ill try to compile with r10 sdk.
by fused » Tue Mar 20, 2007 8:00 pm
@jackei:
i think your problem can be sloved when you assign a cinema material to every object that has a object tag.
i implemented a default material for objects without a material.
new version coming soon (maybe tomorrow, or even today if i can go home before afternoon)
WLAD
by WLAD » Wed Mar 21, 2007 12:23 am
jackei try to export this file
- exporter test.rar
- (20.08 KiB) Downloaded 376 times
Users browsing this forum: No registered users and 130 guests
