SkIndigo 4.2.21.1
8 posts • Page 1 of 1
SkIndigo 4.2.21.1
Post by OnoSendai » Thu Oct 25, 2018 12:02 pm
RBZ:
http://downloads.indigorenderer.com/dis ... 2.21.1.rbz
Windows Installer:
Changelog:
4.2.21.1
Added 'Render Channels' page in settings dialog, Added support for enabling or disabling render channels.
Added checkbox for saving render channels and layers in settings dialog.
Added mask name (for render channels) support for materials and objects (via mesh/component editor)
Removed 'Material_ID' from render mode options (is a channel now instead).
Fixed SketchUp crash when cancelling out of new texture file selection dialog.
Added 'single face' arch glass option for specular materials.
Allowing camera shift-up and shift-right to take 2 decimal values after the point.
Fixed IOR not being exported for simple-thin materials.
Fixed issue where saving IGIs would always be enabled when a custom image name was used.
Fixed setting external mesh path directly in Object/Mesh editor not working.
Fixed view_dependent_subdivision not being exported properly.
Fixed clamp contributions always being exported as enabled.
SkIndigo now shows up in the 'remove programs' dialog in Windows.
Bug reports or other feedback welcome!
Juju
Re: SkIndigo 4.2.21.1
Post by Juju » Fri Oct 26, 2018 5:00 am
This is already included in the 4.2.21 build, yes?
Post by OnoSendai » Fri Oct 26, 2018 3:27 pm
Yup.
bubs
Post by bubs » Mon Oct 29, 2018 5:29 am
Fantastic guys! Thanks for all the hard work!
RDRichards
Post by RDRichards » Fri Nov 02, 2018 3:42 pm
I still can't get any of the recent betas to work on a mac. I'm using the latest version of SketchUp and the most recent version of the Skindigo plugin. When I start SketchUp I get endless requests to locate the Indigo Renderer application. No matter how many times I select it I just get another request. This happens on a 2 different macs on different os version. Any help?
Lal-O
Post by Lal-O » Sat Nov 03, 2018 7:14 am
Thank you very much Ono !!! Testing it out right now. :D
Post by OnoSendai » Tue Nov 06, 2018 12:40 am
This is fixed now, thanks for the report!
https://www.indigorenderer.com/forum/vi ... 69#p142269
RDRichards
Post by RDRichards » Tue Nov 06, 2018 5:53 am
It works! Many, many, many thanks!
Cheers,
Ralph
