Hi there,
does someone would know how to make an Anti Refractive coated Glass material?
thanks
AR coated glass
- thesquirell
Re: AR coated glass
Throw in some examples for us to see!
Re: AR coated glass
https://en.wikipedia.org/wiki/Anti-reflective_coating
it's a glass material showing no or low reflections, only refractions.
very easy to make in biased engine, you only have to set the refraction and remove or set the reflections to black and that's it.
in reality this is a glass with a treatment (coating), i'm not able to reproduce that with the options i got in indigo (or i don't understand it enough, here are the settings i had for it in maxwell
Re: AR coated glass
https://www.molenaar-optics.nl/OptoSigm ... atings.pdf
here's some specifications and tolerances about the coating
