IndigoBenchmark_x64_v4.0.64 works fine on Arch Linux, if I use Arch's opencl-amd package. I'm running the open-source AMDGPU driver, not the proprietary AMDGPU-PRO one. The opencl-amd package extracts the OpenCL libraries only from AMDGPU-PRO, and allows them to run with the open-source AMDGPU driver.
If I switch from the opencl-amd proprietary package to opencl-mesa, IndigoBenchmark crashes. Part of what I'm interested in seeing is how the open-source and proprietary OpenCL packages compare. Furthermore, mesa development is continuing, and it looks like AMDGPU-PRO is somewhat being given up on as a failure and is going to be replaced with AMDVLK, which I don't even know if that's going to be pure Vulkan or if it does or will include OpenCL support.
I'm running: linux 4.18.12.arch1-1, xf86-video-amdgpu 18.1.0-1, mesa 18.2.2-1, opencl-mesa 18.2.2-1, xorg-server 1.20.1-1, and plasma-desktop 5.13.5-1.
I made a bugreport on opencl-mesa here: https://bugs.freedesktop.org/show_bug.cgi?id=108272
Attached there is output from clinfo, lspci, glxinfo, and a gdb backtrace of the crash which is: https://bugs.freedesktop.org/attachment.cgi?id=141935
The pertinent part seems to be:
#0 0x00007ffff6465bb5 in __memmove_sse2_unaligned_erms () from /usr/lib/libc.so.6
#14 0x00007fffb403ec15 in clGetPlatformIDs () from /usr/lib/libOpenCL.so
#15 0x0000000000993a96 in OpenCL::queryDevices() ()
#16 0x000000000099773f in getGlobalOpenCL() ()
#17 0x000000000068d88e in Indigo::HardwareInfoDLLAPI::queryOpenCLDevices() ()
They have (and will probably have more) questions about how IndigoBenchmark is linked. I started with them, but I'm not sure if the bug is actually in their code or Indigo's. I lean toward theirs since with the opencl-amd package, there's no crash.
What version of LLVM is this linked against? Arch has LLVM 7.0.0. Perhaps that leads toward what the issue is.
Indigo Benchmark segmentation fault using opencl-mesa (open-source ATI)
jamespharvey20
Re: Indigo Benchmark segmentation fault using opencl-mesa (open-source ATI)
We're statically linking with LLVM 3.4 on Linux currently.
jamespharvey20
Do you guys think this is a problem running with LLVM 7.0.0, or do you think it's an opencl-mesa issue?
Is there any way to release a version statically linked against 7.0.0?
Again, IndigoBenchmark runs fine on up to date Arch Linux using LLVM 7.0.0, as long as the opencl-amd package is used. (Which is the extracted OpenCL libraries from AMDGPU-PRO, that runs on the opensource AMDGPU driver.)
It's only when attempting to use opencl-mesa that IndigoBenchmark crashes this way.
From the backtrace, it doesn't exactly look like it's an opencl-mesa caused crash. It almost does seem like IndigoBenchmark might be making an LLVM call in a different way with opencl-mesa, but maybe running 7.0.0 has nothing to do with it. Per their suggestion, I tried using an extremely short name string, and that didn't help.
