Indigo Renderer 4.2.20 Beta Release
Post by OnoSendai » Sat Sep 22, 2018 2:17 am
Hi all,
This is mostly a bug-fix release, with the bug fixes mostly being for the render-channel support new in the 4.2.x series.
There's also new documentation on the render channels here: https://www.indigorenderer.com/document ... r-channels
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.2.20_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.2.20.tar.gz
IndigoRenderer4.2.20.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.2.20_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.2.20.tar.gz
IndigoRT4.2.20.dmg
Changelog:
4.2.20
* Fixed issues with null materials and beauty lighting passes.
* Using scene radius with camera for normalising the depth channel.
* Fixed material masks sometimes rendering into the wrong render channel on GPU.
* Made material and object mask names not restart the render on every keypress, but only when editing is finished and a change has been made.
* Fixed crash on enabling emission on materials in some cases.
* Fixed a bug that was occurring with a single object, with non-identity transform, on GPU, with merging disabled.
* Fixed asin function not working on GPU.
* Fixed crash with saving combined EXR.
* Fixed specular reflection lighting channel having incorrect name when saved to disk.
* Fixed bug with shadows being incorrect in some cases on GPU.
* Changed EXR saving to use a layer_name: RGB images are saved as layer_name.R, layer_name.G etc..
* Saving the alpha channel with main layers when saving render channels and layers.
* Fixed light layer thumbnails not working with alpha channel.
* Compositing light layer thumbnails on checkboard background like main render.
* Tweaked handling of processor groups for Windows systems with more than 64 logical processors.
* Fixed non-culling section planes.
* GPU: Added support for non-culling section planes.
* Added save_subdivided_meshes renderer setting option - saves subdivided meshes to disk as igmesh files.
Re: Indigo Renderer 4.2.20 Beta Release
Post by pixie » Sat Sep 22, 2018 3:25 am
Thanks Ono!
Post by zeitmeister » Mon Sep 24, 2018 5:53 pm
Fantastic; thanks Ono!!
noldo
Post by noldo » Tue Sep 25, 2018 5:22 am
If i save a .exr file, the result is black!
Post by OnoSendai » Tue Sep 25, 2018 11:19 pm
noldo wrote: ↑
What software are you using to open the EXR file?
noldo
Post by noldo » Wed Sep 26, 2018 1:31 am
OnoSendai wrote: ↑
noldo wrote: ↑
Photoshop, affinity
Lal-O
Post by Lal-O » Wed Sep 26, 2018 3:21 am
Thank you very much Ono ! Testing it out right now ! :)
burnin
Post by burnin » Wed Sep 26, 2018 8:17 am
confirming black/broken .exr (either with: "Save Image", "Save Un-tonemapped Image" or "Save Layers & Channels")
Tested with: Irfan (black), GIMP (exr plugin crash), picturenaut (black), blender (black)... (png & exr attached)
VelvetEXR.zip
(2.31 MiB) Downloaded 883 times
fourzeronine
Post by fourzeronine » Wed Sep 26, 2018 7:47 pm
noldo wrote: ↑
In Nuke it is in "tonemapped" or "untonemapped" layer.
Post by pixie » Wed Sep 26, 2018 9:19 pm
gpu.igm
(1.89 KiB) Downloaded 789 times
When I use specular reflectivity with shader it all goes black
Post by pixie » Wed Sep 26, 2018 11:45 pm
displacement3.igm
(2.83 KiB) Downloaded 778 times
GPU meltdown!
it doesn't happen with other set of values such as in the material below
displacement.igm
(2.83 KiB) Downloaded 718 times
aleksandera
Post by aleksandera » Thu Sep 27, 2018 4:38 am
Alembic object renders flat shadet in Cycles while in indigo it renders smooth.
Why is that so?
burnin
Post by burnin » Fri Sep 28, 2018 4:17 am
aleksandera wrote: ↑
Why is that so?
Are you using Edge modifier to define edge shading? IIRC, Blendigo doesn't read Normals setting from Blender.
Can you post example file to check?
mriedel
Post by mriedel » Fri Sep 28, 2018 9:42 am
This version of Indigo crashed on me. I can share the scene if you like. An excerpt of the log files is copied below. This same scene did not cause errors on prior versions of Indigo, including 4.2.19.
Thanks,
Marc
OS: Linux Ubuntu, 16.04.2 LTS (Xenial Xerus)
Error Log:
*** Error in `/home/mriedel/Renders/indigo/IndigoRenderer_x64_v4.2.20/indigo_console': corrupted double-linked list: 0x00007ef85aea29a0 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7efe186367e5]
/lib/x86_64-linux-gnu/libc.so.6(+0x82970)[0x7efe18641970]
/lib/x86_64-linux-gnu/libc.so.6(__libc_malloc+0x54)[0x7efe18643184]
/home/mriedel/Renders/indigo/IndigoRenderer_x64_v4.2.20/indigo_console[0x764ed6]
/home/mriedel/Renders/indigo/IndigoRenderer_x64_v4.2.20/indigo_console[0x7eafba]
/home/mriedel/Renders/indigo/IndigoRenderer_x64_v4.2.20/indigo_console[0x7eaf9f]
/home/mriedel/Renders/indigo/IndigoRenderer_x64_v4.2.20/indigo_console[0x7ed271]
/home/mriedel/Renders/indigo/IndigoRenderer_x64_v4.2.20/indigo_console[0x864417]
/home/mriedel/Renders/indigo/IndigoRenderer_x64_v4.2.20/indigo_console[0x84a1da]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba)[0x7efe1944b6ba]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d)[0x7efe186c641d]
RDRichards
Post by RDRichards » Sat Sep 29, 2018 9:07 am
I am using SketchUp 18.0.16976 (2018) on an iMac running OS 10.13.6. I have the SkIndigo plugin version 4.0.61.2.
I am unable to get SketchUp to recognize any version past 4.0.66. I get repeated dialogs to choose the location of the Indigo application. I have not renamed the folder which is itself located in the Application folder.
Any help?
Cheers,
Ralph
