Indigo for Revit 2018
Any idea when Indigo for Revit installer will have the install option for the 2018 version?
Nikolaj Knudsen
Re: Indigo for Revit 2018
Hey all
Any news about the 2018 plugin? I have a project coming up in Revit 2018 soon, need to plan a workflow ahead
Nik
Nik
We are working on a Revit 2018 build currently.
Hi
This plugin would be AMAZING right now - any idea when 2018 will be ready?
sorry for the long dealy. You can find the 2018 plugin here: https://www.indigorenderer.com/forum/vi ... 38&t=14791
Re: Indigo for Revit 2019
Sorry to ask the obvious question but when will you add support for Revit 2019!
Keep up the great work - Thanks
Nikolaj Knudsen
I have a small problem with the exporter:
Render settings are not stored. Quite annoying on bigger cases. Can't pick other than first camera for instance.
Nik
Nik
There will be a build for Revit 2019 soon.
I thought we fixed this bug quite a while ago. Are you using the latest version of the plugin?Nikolaj Knudsen wrote: ↑Thu May 03, 2018 11:35 pmI have a small problem with the exporter:
Nik
Nikolaj Knudsen
Hi Fused
Yes, latest plugin v2018 - 2017 is fine
Nikolaj Knudsen
Any news on this problem? - really need to control the views and settingsfused wrote: ↑Tue May 15, 2018 6:33 am
Nik
Another question: are ies profiles exported from lights or materials in Revit and how?
Hi,Nikolaj Knudsen wrote: ↑Fri Jun 08, 2018 11:04 pmAny news on this problem? - really need to control the views and settings
try this build: https://www.indigorenderer.com/forum/vi ... 38&t=14884
please let me know id this solves the problem for you.
Regarding IES profiles: IES profiles are read from revit light sources, depending on the "distribution" set in the asset:
- For "Spot" an IES file is generated from the spot parameters.
- For "Web" the referenced IES file is used.
- For all other IES is not set.
Nikolaj Knudsen
Hi Fused
Sorry, but it dosn't solve it. I can change the different settings but it jumps back again to default values.
Could it be some security settings is blocking the read/write access to something?
Regarding ies profiles -how do I control the strength then? Are the ies profile tied to a material?
Nikolaj,Nikolaj Knudsen wrote: ↑Thu Jun 14, 2018 1:49 amHi Fused
the only change in 2018 that I could think of being related to this issue is that the automatic transaction mode was removed and transactions always have to be handled manually now.
I have checked the transaction error handling code again, and if that were the cause, there there should be an error message.
I'm currently going over some other code improving error handling. If you could send me a pm with a contact where I can send builds for you to try, that would be greatly appreciated.
Users browsing this forum: No registered users and 89 guests
