Mac Pro: OpenCl rendering: max path depth
5 posts • Page 1 of 1
tornello
Post by tornello » Mon Feb 19, 2018 11:45 pm
Hello I have a Mac Pro and I can't understand 2 things :?
I have 2 AMD FirePro D500 3 GB and when I open Indigo render settings I see in the list of OpenCl also the Intel Xeon CPU E5-1650 see screenshot
1) When I use OpenCl rendering is it better to use also Xeon CPU?
2) What is the numbers of "max path depth" to use?
Thank you to read my terrible english
Re: Mac Pro: OpenCl rendering: max path depth
Post by lycium » Tue Feb 20, 2018 5:42 am
To answer your questions,
1. It's probably better not to use the CPU, though you are welcome to do a quick test to see if it helps
2. It's the number of bounces of light to compute with the GPU, I think you could use a default value of 8 and maybe try higher if you have very complex glass scene or something.
tornello
Post by tornello » Tue Feb 20, 2018 6:14 am
Hello and Thank you very much for your answers :D
I am testing last Indigo for the first time and so 8 is default number, regardless of the power of the PC?
Post by lycium » Tue Feb 20, 2018 11:09 am
Yes, it only affects the number of indirect illumination bounces; 8 is fine for basically all scenes except with complex glass reflections and refractions.
Users browsing this forum: Majestic-12 [Bot] and 9 guests
