interior renders
8 posts • Page 1 of 1
devrim
interior renders
Post by devrim » Sun Jul 09, 2017 10:32 pm
Hello;
Can anybody help me to solve for noises.? I am using sketchup indigo. I have only 2 light sources; sun and sky. If I add some other lights İt is seen on the scence and I do not want it.
Thanks in advance.
(sorry for my English )
Re: interior renders
Post by Oscar J » Sun Jul 09, 2017 10:47 pm
Hmm, looks odd. Do you use arch glass for your glass panel? What rendering mode? Have you tried using exit portals for those windows? :)
devrim
Post by devrim » Mon Jul 10, 2017 9:20 am
Hi.
1) I am using arcg glass.
2) render mode is bidirectioanal path tracing
3) No I am not using exit portals ( İn fact I have no idea how to use exit portals)
Regards
devrim
Post by devrim » Mon Jul 10, 2017 9:26 am
I am sending one another render. İt looks better. But I still have noises.
Regards
Post by Oscar J » Mon Jul 10, 2017 10:43 am
Well, that could be an acceptable noise level depending on how long it's been rendering. With CPU rendering, interiors can take hours depending on the scene, resolution and CPU.
Exit portals: https://www.indigorenderer.com/document ... s-sketchup
Depending on what lighting you use, exit portals don't always give favourable results currently.
Post by Zom-B » Mon Jul 10, 2017 6:31 pm
lighten an room through glass & curtain material is render intensive, so noise will take time to vanish.
You can make sure to disable glass & curtain meshes from windows that are not in camera focus to allow faster rendering.
Also if you are using some texture for the curtain with a BW mask to control solid & transparent holes on a microscopic level, you can try to enable "step blend" for that texture. That should give some slightly faster rendering too...
Bosseye
Post by Bosseye » Wed Jul 12, 2017 9:06 pm
Check your white wall material too - make sure its not rgb 255,255,255. Thats pure white and will extend render times a lot which manifests as a lot of noise after a long time. Make sure your white values are around 205,205,205 gives acceptable whites, without dragging the render process out for a week.
Eneen
Post by Eneen » Wed Jul 12, 2017 11:21 pm
Actually white paint has albedo about 80%, so setting RGB to about .91 is still ok as RGB values are gamma-corrected.
