Hey there,
I noticed that case from time to time. I've got a scene here which doesn't startup in the realtime preview window.
I added the scene into a new one, no chance. I emptied the quickrender folder, no luck.
Restarted the computer, the same.
What else can I do? Which prefs or folders do I have to clear or delete to get it working again?
C4d R14, Cindigo 4.0.48, Windows 7.
Thanks in advance!
Realtime preview doesn't work anymore
- zeitmeister
- zeitmeister
Re: Realtime preview doesn't work anymore
Edit: Same with latest Cindigo 4.0.51
- Originalplan®
Hmmm.... in Cinema IPR works well on Mac.
Cinema Update??
Cinema Update??
- zeitmeister
No, it's always okay to a certain point. It works in new scenes. But at some point, it stops working in a certain scene. Now it doesn't export to Indigo GUI anymore.
I guess I have to import object by object into a new scene to figure out what's happened.
IIRC - It could be (& most likely is) a missing texture problem (path changed, either moved or removed) since Indigo doesn't communicate with Cinema's Texture Manager you will get no errors, but simply no action, no response. In such case, only manual check & fix works.
- zeitmeister
Supposed that... thank you! Didn't change anything there consciously...
Thanks burnin, will fix.
