Originalplan®'s rendering corner
- Originalplan®
Re: Some renders for CLASSICS & PATTERNS
Nice, but I'm not sure I understand the ground mat.
- Originalplan®
Well something like in the pic below just more wet & dark.
(The green below the projected image comes from Neons..the rods you see going horizontally across. )
Just experimenting...
For more natural not so artistic picks >> visit
Ah, ok. Are you doing it using interference?
- Originalplan®
No, but i should... since some ISL does not show up on GPU yet.Oscar J wrote: Are you doing it using interference?
( hint* for a 25/s moving image would be nice to have just for speed.
Right now the mat is a small bit of ISL on the thickness front on a phong mat.
And that is blended together in c4d with c4d's native noise in a separate mat.
So there is 3x noise on roughness, bump, displace..etc and that is blended together with the same negative noise = for the blend mat. Hope makes sense..
Anyway kinda the scenenery should be some dark bit futuristic environment ....since the whole thing YAMAHA has revolves around " the dark side of Japan "
(1)
(2) ...some idea base.
- Originalplan®
Please Don't Touch the Be@rbrick
Good detail fingerprints!
When there is an option bear mummy? Egypt, Pharaoh
- Originalplan®
Will do one @Zalevskiy not sure when but will do. : )
- Originalplan®
Kept you waiting, huh?
Wet Be@rbrick.
Wet Be@rbrick.
- Originalplan®
- zeitmeister
Hehe, nice! Reminds me of the gumballmachines in my youth...
- Originalplan®
@zeit Thanks!
- Originalplan®
- Originalplan®
- Originalplan®
