Post producción options
11 posts • Page 1 of 1
Lal-O
Post by Lal-O » Sun Jan 01, 2017 5:28 am
Hi guys...I was thinking that it would be nice to have some post production options...like glare, fog, chromatic aberration.. Etc, etc... The glare feature is the most important (to me) so i could have effects in the Sky and lights like the images below :
Cheers :D
Originalplan®
Re: Post producción options
Post by Originalplan® » Sun Jan 01, 2017 5:33 am
Put this on the camera it will get you glare & bloom.
Chromatic abe would be nice..but only a minimal amount too much and it ruins the pic IMO.
Lal-O
Post by Lal-O » Tue Jan 03, 2017 8:03 am
Thanks for the reply. It seems really interesting ... but how do i do that ? this is the first time i hear is possible to achieve that effect with an obstacle camera map... in fact i don't have a clue about how to use that option. :shock:
Originalplan®
Post by Originalplan® » Tue Jan 03, 2017 8:17 am
Lal-O wrote:Thanks for the reply. It seems really interesting ... but how do i do that ? this is the first time i hear is possible to achieve that effect with an obstacle camera map... in fact i don't have a clue about how to use that option. :shock:
Just experiment with them or make your own obstacle map. You won't get fog or anything like that. But you will get nice effects for lights and even the sun lights with the right settings.
Not sure...in c4d it's few clicks to get maps on the cam. If you are on c4d i can help if not i can't.
( you won't get chromatic abe from this.Just to be clear.)
thesquirell
Post by thesquirell » Tue Jan 03, 2017 8:25 am
Well, basically, it's about this effect called Aperture diffraction. Inside Indigo, it can be achieved through Post-processing mode, or physical. They are both equal in accuracy, only the post-process one demands more RAM, while the physical one kinda grows/samples as your scene sampling progresses with it.
You can find more about it here:
http://www.indigorenderer.com/documenta ... iffraction
As for the effect, putting an obstacle map will basically change the final look of the aperture diffraction. You can load this map, usually in the camera object properties, but it depends on the host app you are using. I can help you only with Cinema 4D, but the principle is the same.
The general shape can be determined by the aperture shape, which can be generated by Indigo, or by user, through the use of a map. Also, the effect itself depends on the f-stop.
Check this topic out:
http://www.indigorenderer.com/forum/vie ... =7&t=11730
Happy hunting! :D
Lal-O
Post by Lal-O » Tue Jan 03, 2017 4:18 pm
Ok..I see, unfortunately i am not a C4D user . I should have mention that before. I use SketchUp.
Thx for the info anyway. Respect :D
Lal-O
Post by Lal-O » Tue Jan 03, 2017 4:26 pm
thesquirell wrote:Well, basically, it's about this effect called Aperture diffraction. Inside Indigo, it can be achieved through Post-processing mode, or physical. They are both equal in accuracy, only the post-process one demands more RAM, while the physical one kinda grows/samples as your scene sampling progresses with it.
Happy hunting! :D
Thx for the info thesquirell, i guess tha was exactly what i was looking for . I just didn't like the extra RAM and rendering time consumption.(i already have enough suffering dealing with the displacement materials). Anyway , the bloom /glare effect is really cool to give it a try :D .
Regards
Eneen
Post by Eneen » Tue Jan 03, 2017 10:51 pm
Indigo lacks options to change type of glare/bloom during and after rendering, so to change look you have to re-render (we are talking about post-processed mode of course). It also calculates it every refresh so slows down first couple of minutes of rendering.
You also can't adjust intensity of diffraction as it depends on aperture setting, so it will also alter dof. I've made req for that here:
http://www.indigorenderer.com/forum/vie ... =7&t=13830
Workaround is to render in f/22 and mix with non post-processed image (untick "enable aperture diffraction"). It will give very similar result.
Lal-O
Post by Lal-O » Sat Nov 03, 2018 8:32 am
I have seen some other rendering programs (biased & unbiased) that uses this ADJUSTABLE post production options, some of them won't take to re-render the image to apply the FX options. Vray Fx works after the rendering is finished, Thea during and after the render process, Fryrender and Arion during and after the render process,but it takes to re-star the render even to adjust camera settings (ISO,DoF..etc etc...by the way , this last 2 programs are not longer available in the market ).
So,in the end , indigo is way better than the programs named before and i don't see why indigo would not implement these features if the other programs could.
I am not a programmer just an indigo user and i don't know what it takes to bring all this stuff to indigo, maybe im asking for some silly things so i apologize in advance if this is the case :D.
My Best Regards :D
Post by Oscar J » Sat Nov 03, 2018 10:10 am
I agree with your request, would be really useful.
Post by zeitmeister » Sat Dec 01, 2018 6:41 pm
Oh yeah!
Users browsing this forum: No registered users and 101 guests
