Indigo Renderer 4.0.46 Beta Release
Re: Indigo Renderer 4.0.46 Beta Release
Hi guys,
Will this beta release work on Sketchup 2017? I am thinking of upgrading SketchUp from 2016 to 2017.
Any feedback would be helpful.
Thank you,
Thank you,
Yes it does.Iamme wrote:Will this beta release work on Sketchup 2017? I am thinking of upgrading SketchUp from 2016 to 2017.
Hey,
just downloaded the Beta 4.0.46, it does not recognize my nVidia GTX 1070 as an OpenCL device - it says "No supported OpenCL devices" in the OpenCL Rendering tab.
Is there anything I should do or configure or is this GPU not supported?
GPU Rendering was working fine with the stable 3.8.29 version.
I'm using Windows 10 Pro and the 64bit version of Indigorenderer 4.0.46.
Thanks,
Thanks,
Please install the latest display drivers from Nvidia: http://www.nvidia.com/Download/index.aspx?lang=en-us
I do already have the latest drivers, version 375.86 released just today.
- Originalplan®
GLOSSY Materials RGB spectrum containing color data don't show up on OpenCL render.
Ono Sempai please do some magic about it. ^ _ ^
That's so strange. The GTX 1070 is definitely supported, it's pretty much the best GPU for Indigo 4 right now, I have one in my computer.walnist wrote:I do already have the latest drivers, version 375.86 released just today.
I really can't think of any reason why it isn't being detected on your computer, there are many GTX 1070 owners using Indigo just fine
What OS? System configuration? Any other strangeness?walnist wrote:Hey,
Thanks,
There is nothing strange with my configuration, it worked fine with Indigo 3.8, this is the system information:
Betriebssystem: Windows 10 Pro, 64-bit
DirectX-Version: 12.0
GPU-Prozessor: GeForce GTX 1070
Treiberversion: 375.86
Direct3D-API-Version: 12
Direct3D-Funktionsebene: 12_1
CUDA-Kerne: 1920
Kerntakt: 1594 MHz
Speicher-Datenrate: 8008 MHz
Speicherschnittstelle: 256-Bit
Speicherbandbreite: 256.26 GB/s
Gesamter verfügbarer Grafikspeicher: 16297 MB
Dedizierter Videospeicher: 8192 MB GDDR5
System-Videospeicher: 0 MB
Freigegebener Systemspeicher: 8105 MB
Video-BIOS-Version: 86.04.1E.00.68
IRQ: Not used
Bus: PCI Express x16 Gen3
[Komponenten]
NvGFTrayPluginr.dll 3.1.0.52 NVIDIA GeForce Experience
NvGFTrayPlugin.dll 3.1.0.52 NVIDIA GeForce Experience
nvui.dll 8.17.13.7586 NVIDIA User Experience Driver Component
nvxdsync.exe 8.17.13.7586 NVIDIA User Experience Driver Component
nvxdplcy.dll 8.17.13.7586 NVIDIA User Experience Driver Component
nvxdbat.dll 8.17.13.7586 NVIDIA User Experience Driver Component
nvxdapix.dll 8.17.13.7586 NVIDIA User Experience Driver Component
NVCPL.DLL 8.17.13.7586 NVIDIA User Experience Driver Component
nvCplUIR.dll 8.1.930.0 NVIDIA Control Panel
nvCplUI.exe 8.1.930.0 NVIDIA Control Panel
nvWSSR.dll 6.14.13.7586 NVIDIA Workstation Server
nvWSS.dll 6.14.13.7586 NVIDIA Workstation Server
nvViTvSR.dll 6.14.13.7586 NVIDIA Video Server
nvViTvS.dll 6.14.13.7586 NVIDIA Video Server
NVSTVIEW.EXE 7.17.13.7586 NVIDIA 3D Vision Photo Viewer
NVSTTEST.EXE 7.17.13.7586 NVIDIA 3D Vision Test Application
NVSTRES.DLL 7.17.13.7586 NVIDIA 3D Vision Module
nvDispSR.dll 6.14.13.7586 NVIDIA Display Server
NVMCTRAY.DLL 8.17.13.7586 NVIDIA Media Center Library
nvDispS.dll 6.14.13.7586 NVIDIA Display Server
PhysX 09.16.0318 NVIDIA PhysX
NVCUDA.DLL 6.14.13.7586 NVIDIA CUDA 8.0.0 driver
nvGameSR.dll 6.14.13.7586 NVIDIA 3D Settings Server
nvGameS.dll 6.14.13.7586 NVIDIA 3D Settings Server
Any steps i can take to try to diagnose the problem?
Is there an error log or anything like that?
CUDA-Kerne: 1920
Kerntakt: 1594 MHz
IRQ: Not used
[Komponenten]
at this scene with GPU freezing process 0.34 spp (without errors)
after re-click on the play
clCreateContextFromType failed: CL_DEVICE_NOT_AVAILABLE
- curl_noise_shader_test.pigs
- (56.94 KiB) Downloaded 577 times
Intreresting, renders fine for me:Zalevskiy wrote:at this scene with GPU freezing process 0.34 spp (without errors)
Auto setting number of threads to 4.
Finished initialisation (Time Taken: 0.29 s)
OpenCL code for Quadro K2200 built. (elapsed: 1.493 s)
OpenCL code for 'diffuse_nonbasic_3382283500554362621' on Quadro K2200 built. (elapsed: 12.47 s)
Starting threads... (num threads: 4)
Starting render thread. (RNG seed=0)
Converting original sky model to captured-simulation for GPU rendering.
Optimised OpenCL code for 'diffuse_nonbasic_3382283500554362621' on Quadro K2200 built. (elapsed: 9.618 s)Re: Indigo Renderer 4.0.46 Beta Release
So i found the problem.
On the same PC I had an AMD Radeon GPU previously installed, and apparently the driver uninstall process left quite some stuff behind, including the AMD opencl dlls being registered.
With some painful registry cleaning, i could now get the GTX 1070 working with Indigorenderer.
Best,
Best,
Same here. No problems.
@walnist
Thanks for the info.
Which AMD card do you use? (you didn't listed any)
Does it work in unison with the 1070?
@walnist
it's time to throw my laptop with Nvidia 750M in the trash
:/Zalevskiy wrote:it's time to throw my laptop with Nvidia 750M in the trash
Indigo OpenCL definitely seems to favour new NVIDIA GPUs a lot over older ones.
Users browsing this forum: No registered users and 97 guests
