Issue with Skatter
jiminy-billy-bob
Issue with Skatter
There's an issue when using Skatter's "Render Only" feature with Indigo.
It works fine if we scatter a simple component, but if there's another group/comp nested in this component, it won't be rendered.
I attached an example file. There's already a Skatter setup, you'ill find it in the Render List tab in the Skatter dialog.
This is a big issue, as the whole Skatter library is set up with nested components like that, so users are not able to render these assets.
- indigo_render_only.zip
- (171.9 KiB) Downloaded 535 times
Re: Issue with Skatter
Yes I have the same problem,
see image,
if I click "render only" the skatter group is not rendered, neither as a simple object nor with nested groups.
if I untick "render only" it will be rendered but makes Sketchup extremely slow especially with the likes of grass.
I have Indigo RT v3.8.34 and Sketchup 2016
see image,
I hope the developers will take a look at this soon, as it's very important for us to use the marvelous plugin!!!!!
Hey Bob! Any news from the devs?
I just downloaded v.1.2 and seems great, I wanted to use the gravel feature but I can't even think about it if proxies aren't supported...
jiminy-billy-bob
Sadly, no.Pibuz wrote:Hey Bob! Any news from the devs?
Ono, please! Give some feedback to our Bob!
Will make time to look into this soon.
Hi guys,
same problem here...please Ono...fix it
This plugin is really useful and beautiful...
Thanks a lot
Thanks a lot
Carpe diem...quam minimum credula postero...
Ok I have hopefully fixed this problem, please try this build:
http://www.indigorenderer.com/forum/vie ... 17&t=14191
thanks for the effort Ono, it seems SU2017 is having a number of problems with extensions / plugins, mainly licencing it seems, I've stalled my SU2017 uptake until it gets sorted
jiminy-billy-bob
Great, thanks a lot!
We expect a flash-release of skatter supporting render-only indigo instances now
Thanks Ono and Bob!
Thanks Ono and Bob!
Are you asking for a new feature Pibuz?Pibuz wrote:We expect a flash-release of skatter supporting render-only indigo instances now![]()
Thanks Ono and Bob!
I'm actually talking to Bob, Ono
He knows what I mean (I hope)
