Landscapes
- arc en ciel
Re: Landscapes
there is a plug-in for large file : http://www.vim.org/scripts/script.php?script_id=1506
or
you can try to split the file in multi small files : http://www.gdgsoft.com/gsplit/
and
concate them after modifications : http://www.gdgsoft.com/gsplit/gunite.aspx
or
if you export from c4d some limited parts of the scene, and off course you can edit them, change <scene> to <scenedata> and add some
<include>
<pathname>xxx.igs</pathname>
<offset_uids>true</offset_uids>
</include>
in the last .igs exported
in this last case, if the scatter is referencing to an objet in an other file, you need to change
to
<offset_uids>false</offset_uids>
but
when doing that you can have the same uid for differents objets, so
you can run in previous small .igs exported (<scenedata>) a search and replace like that :
search : "uid>"
replace : "uid>1234"
off course the sequence 1234 must be different for each search/replace for each file modified
this will add 1234 after the closed </uid>, but Indigo can run with that, I already tried
Attention
if you add a scatter in a <scenedata> file
this file have to be included using
if not, some uid referenced in the scatter will cause trouble, even if the proto(s) objet(s) are in the same file
... from memory, have to be confirmed
EDIT : you can call a scatter inside an external file without necessary have to do <offset_uids>false</offset_uids>
off course, proto(s) object(s) must be in the same file with the scatter code
Attention
if you use the restricted area/material code with the scatter, remove the prefix 1234, or indigo will return an error
or
and
or
<include>
</include>
to
but
search : "uid>"
Attention
Attention
Re: Landscapes
Thanks for the info! What a lesson of XML ...
Another kind of approach. With a predisplaced terrain from satellite data and premeshed clouds to help composition. First attempt. I decide to stop it at 1000 spp because the speed decrease ...
Is the peak of the Mount Ruapehu, a volcano in New Zealand. It is supposed that there must be snow.
A impression then.
A impression then.
Re: Landscapes
Those clouds look sexy, but there are some visible edges there taking the realism off. The mountain needs work.
Keep it up!
Keep it up!
Re: Landscapes
Thanks for the push up!
A general take with one material. It begins to be something, a mix of some ISL codes and some maps.
I forgot that I´m not able to do fbm´s displacements, but bumps do it in a strange mode.
I feel a lack of modularity in the general shape but here goes.
To progress something in it I must do a lot of ISL questions.
Now I have zero time, sorry. For more over...
Re: Landscapes
Now those are nice mountains.
Re: Landscapes
But there is a bug working with slope and ISl. I´m not able to displaced the snow (only bumped).
Now I need to know from where this image become: I don´t remember how I obtained this image. Is reduced and banded, but more or less...
I believe that all the surface of the Earth is well mapped, but where can i find it?
- Originalplan®
Re: Landscapes
@yonosoy supa cool!
- zeitmeister
Re: Landscapes
Great!
Re: Landscapes
Thank you both, very kind.
Now I understand how the material slot of the scatter works. Is all between the lines...
The material receptor needs a tag and the UID object tag of the scatter needs an entry that indigo don´t process!!!
In the material:
<scatter_uids>
<uid>700</uid>
</scatter_uids>
And a incoherent value for the object slot:
<target_object_uid>4294967295</target_object_uid>
Thanks.
Now investigating some basic ISL for landscaping.
See you.
In the material:
<scatter_uids>
<uid>700</uid>
</scatter_uids>
Thanks.
See you.
Re: Landscapes
A wip test with 37 million of instances. 21 GB of ram used...
Re: Landscapes
awesome
Re: Landscapes
Re: Landscapes
Re: Landscapes
New tools in Houdini 16 for terrains.
3 min. render.
134+ Millions of unique triangles. 2x2 km.
3 min. render.
- Originalplan®
Re: Landscapes
Love it!
