Indigo Renderer 4.0.45 Beta Release
Re: Indigo Renderer 4.0.45 Beta Release
a database of materials!
del
You can download any material or directory separately, you must move the mouse button and in the menu click "скачать"Can someone host this on a server so I can use a download manager to download?
Can also search for pumping the individual materials (selected checkbox)
Also useful for those who need to download again ALL materials in one zip archive
I do not know how anyone, for me it is a very useful catalog, it saves my time and does not overload the server is offline Indigo :)
impressive work
shows great effort and dedication
useful indeed, especially if it can be downloaded all in one ZIPZalevskiy wrote:You can download any material or directory separately, you must move the mouse button and in the menu click "скачать"Can someone host this on a server so I can use a download manager to download?
the internet connection here is a little flaky lately, bandwidth also limited; I'd like to use download manager so I can limit the amount of bandwidth used and resume the download in the event of it being interrupted
hopefully the code to import local material database will show up soon, I have not seen it in the changelogs since Ono mentioned that they have code to this effect and will incorporate it
just a query on the functionality of the region render. In previous versions (3.x) you could use the select region tool during a render, click 'stop' and when you restarted the render you got the region render you were after. It seems with only the pause button you can no longer do this? Or am I missing something?
You're not missing anything, this needs to be fixedbubs wrote:just a query on the functionality of the region render. In previous versions (3.x) you could use the select region tool during a render, click 'stop' and when you restarted the render you got the region render you were after. It seems with only the pause button you can no longer do this? Or am I missing something?
- Originalplan®
Just a heads up 4.0.45 runs slower on the new macOS then El Cap. ( On GM release )
Maybe it's an OS build thing.But worth a look if it drops.
MacOs 10.12 Sierra GM?
- Originalplan®
yes obviously..contegufo wrote:MacOs 10.12 Sierra GM?
Using GPU or CPU?Originalplan® wrote:Just a heads up 4.0.45 runs slower on the new macOS then El Cap. ( On GM release )
Can you post some measurements?
Esenistras
it solved R9 290 and 390 series memory leaks too !
- Originalplan®
Using GPU.OnoSendai wrote:Using GPU or CPU?Originalplan® wrote:Just a heads up 4.0.45 runs slower on the new macOS then El Cap. ( On GM release )
Well i can't post exact numbers i did go back to El Cap this morning Sierra GM was slow for now.
But rendering the same polar bear scene i did the Light kit with..it renders on El cap about 2:20 on fixed 2000sp and rendered on Sierra over 3mins with the same dual GPU setting.
Hope this helps. Maybe it was the build and some minor stuff missing still....but it will drop 3 days from now.
So worth a look.
Hello!
Just want to add how great this latest update was!
Can anyone please clarify something for me, when rendering an image sequence...
If I set a target sample # per image, it seems the rendering per-image does not stop when that sample # is reached? Rather it seems like it keeps going until (1) the target sample has been met AND (2) the current 'Next Image Update' timer completes?
Unless I am doing something wrong, it seems like to optimize a render of images for a sequence you would have to catch the highest sample amount within a specific window, otherwise you are penalized and have to wait for the following 'Next Image Update' timer episode to complete.
Is there any way to truly cap an image rendering at a specific value such that the completed image is not merely > than the target sample amount, but = the target sample amount. It seems like a rendering project wastes time completing a 'Next Image Update' cycle for inertia's sake rather than moving to next frame once sample count target is met.
Tony D.
Tony D.
Tony: Indigo GPU renders each pass with tiles internally, which means that an image saved in between updated frames would have visible tiles with more noise. There could still be some optimisation for this though. :)
Users browsing this forum: No registered users and 112 guests
