Indigo for Cinema 4D 4.0.43.2
contegufo
Re: Indigo for Cinema 4D 4.0.43.2
Post by contegufo » Thu Aug 18, 2016 11:38 am
The "Real Time preview" window does not match the OpenGL; also rendering in the viewport is not the same. The project texture change is not updated.
Bugs of texture?
C4D R13 (v13.061) + Cindigo 4.0.43.2 + Indigo 4.0.42
PS. Now tried again with an empty stage and new object the problem does not appear, however, the new material is NOT saved.
Post by zeitmeister » Thu Aug 18, 2016 6:14 pm
Spatial texture mapping is not recognized by Indigo!
Only these mapping types are seamlessy integrated: Spherical-, cylindrical-, box-, planar- and UV-mapping.
For all other mapping types you have to create a new UV-map. Try to delete the UV-tag from the sphere, mark the Material tag and choose from the menu "create UV coordinates".
If the material tag now shows "UV mapping" instead of "spatial" and it looks the same, everything is fine.
If not, even C4D can't bake these UVs, and so Indigo won't, too.
Cheers, zeiti
Post by Zom-B » Thu Aug 18, 2016 6:37 pm
zeitmeister wrote:Only these mapping types are seamlessy integrated: Spherical-, cylindrical-, box-, planar- and UV-mapping.
Since the v4 builds camera mapping will get transformed to good UVs too and there for work as well 8)
contegufo
Post by contegufo » Thu Aug 18, 2016 7:44 pm
Hi
Flat, Frontal and Spatial work fine and are rendered by Indigo. Maybe it's a sporadic problem in some settings block that are not updated, in fact at a later time it all seemed to work. Or maybe it's a problem of the object sphere? Other objects are rendered and updated in exchange for mapping.
contegufo
Post by contegufo » Thu Aug 18, 2016 8:01 pm
Hi
Here is the proof that it is a problem with the ball does not update changed to different mapping.
Originalplan®
Post by Originalplan® » Thu Aug 18, 2016 10:00 pm
contegufo wrote:Hi
@contegufo the problem still ON if you make the sphere editable?
Originalplan®
Post by Originalplan® » Thu Aug 18, 2016 10:01 pm
@Mr.fused How are we holding the line on update front? 8)
Post by fused » Thu Aug 18, 2016 10:23 pm
Originalplan® wrote:
contegufo wrote:Hi
Yeah I would also say the problem is that you are using Indigo's perfect sphere. Try unchecking "perfect" on the sphere.
Post by fused » Thu Aug 18, 2016 10:24 pm
Originalplan® wrote:@Mr.fused How are we holding the line on update front? 8)
I've been a bit sick the last couple of days. Maybe today is a good day for an update. Don't expect anyhing huge :)
Post by fused » Thu Aug 18, 2016 10:32 pm
zeitmeister wrote:Spatial texture mapping is not recognized by Indigo!
Cheers, zeiti
Last time I tried all types of texture mapping worked. According to ZomB I fixed some sort of bug there. It's possible. :)
Originalplan®
Post by Originalplan® » Thu Aug 18, 2016 10:35 pm
:shock: :shock: OH NO! Get well soon Mr.fused we need you!!!
Originalplan®
Post by Originalplan® » Thu Aug 18, 2016 10:36 pm
ZomB is right, you did fixed something cam map did not work previously.
Post by zeitmeister » Thu Aug 18, 2016 11:36 pm
Oh, this "new" baking sounds great!!
Always played save and converted the UV by myself...
Cheers, zeiti
contegufo
Post by contegufo » Thu Aug 18, 2016 11:56 pm
"Try unchecking "perfect" on the sphere."
OK! Work.
Get well soon, best wishes!
contegufo
Post by contegufo » Tue Aug 23, 2016 4:35 am
Hi
I would like to report a problem that appears when you activate the Indigo Tags subdivision function. It seems to have an influence on the texture that appears with the artifacts. Removed the tags or by withdrawing to its qualities; the problem does not appear. Perhaps in these cases you should opt for the C4D HyperNURBS function? :(
