Scatter editor test: Forest
Antonis777
Re: Scatter editor test: Forest
Post by Antonis777 » Mon Feb 09, 2015 10:53 am
I see. What about the fact that I tried unsuccessfully to upload my scene? Is there a mb limit?
Jay-ko
Post by Jay-ko » Thu Aug 18, 2016 3:52 am
Hi Antonis,
Could you explain how did you obtain this nice spectral glare?
I really like this!
errare humanum est
Antonis777
Post by Antonis777 » Thu Aug 18, 2016 5:07 am
Jay-ko wrote:Hi Antonis,
I really like this!
I used two pictures, one as aperture and one for obstacle map my friend I think they are inside the Indigo build. I also did it by putting the camera facing the sun. I hope that helps.
Post by zeitmeister » Thu Aug 18, 2016 6:17 pm
Would you mind to share thumbnails of these 2 maps? Me didn't achieve such a glare ever, too.
Cheers, zeiti
Antonis777
Post by Antonis777 » Fri Aug 19, 2016 7:15 am
Went back to my scene and checked. I used Indigo's default square aperture map and this photo as obstacle map. Blade offset 0.3 and radius 0.7 at -4 angle.
Post by zeitmeister » Fri Aug 19, 2016 10:42 pm
Thank you very much!!
Cheers, zeiti
Jay-ko
Post by Jay-ko » Fri Aug 26, 2016 4:19 am
Thank you Antonis,
But I need a bit more explanation to understand well your method to obtain this nice effect, maybe because I do not use the same exporter than you (you probably use Cindigo)?
For example I am very surprised to learn that Indigo have "default aperture maps".
Where can I found that such a map?
  • When I scan the install directory, I can found a "Obs/" folder but the files there are not bitmap images?
In the camera settings I have added
	<obstacle_map>obstacle.png</obstacle_map>
	<aperture_shape>
            <generated>
                <num_blades>16</num_blades>
                <blade_offset>0.200000</blade_offset>
                <blade_curvature_radius>2.000000</blade_curvature_radius>
                <start_angle>0.100000</start_angle>
            </generated>
        </aperture_shape>
I also use your proposed settings.
I am not sure about the way to declare the obstacle map:
should I have to use "<path>" indeed?
I do not succeed to obtain the nice rainbow effect that you have, even with a kind of eyelashes or dust, and it's probably becasue of the way to add it into the igs.
errare humanum est
Antonis777
Post by Antonis777 » Sat Aug 27, 2016 7:53 am
Jay-ko I sent you the files in a pm
Users browsing this forum: No registered users and 150 guests
